Component: LinearSlider (Controls)
Revision as of 09:11, 12 October 2020 by BenR (talk | contribs) (XML import)
Author Steve Tandy
Version 0.1 (Development)
Category Controls
Image LinearSlider component
A linear 2d slider component.
This component does not contain any downloadable macros
Simulation macro reference
GetValue
Returns the current value of the component.
This macro has no parameters
FLOAT
SetValue
Sets the component to the specified value.
FLOAT value
A new value for the component.
Value
This property is of type Floating point and can be referenced with the variable name Base2dGauge::Base2dObject::dValue.
Style
This property is of type Fixed list of text and can be referenced with the variable name nStyle.
Orientation
This property is of type Fixed list of text and can be referenced with the variable name nOrientation.
Pointer
This property is of type Fixed list of text and can be referenced with the variable name nPointer.
Discrete Values
This property is of type True or false and can be referenced with the variable name bDiscrete.
Lower Bound
This property is of type Floating point and can be referenced with the variable name Base2dGauge::dLowerBound.
The bottom value of the scale.
Upper Bound
This property is of type Floating point and can be referenced with the variable name Base2dGauge::dUpperBound.
The top value of the scale.
Major Tick Step
This property is of type Unsigned integer and can be referenced with the variable name Base2dGauge::dMajorTickStep.
The number of minor tick marks to show a major tick mark value.
Minor Tick Step
This property is of type Floating point and can be referenced with the variable name Base2dGauge::dMinorTickStep.
The scale value between consecutive minor tick marks.
