Component: Multiplex (DSP)
Author | Matrix Ltd |
Version | 1.2 (Release) |
Category | DSP |
Multiplex component
Allows multiple input buffers to be multiplexed to a single output buffer.
Multiplex
Passes a single value from the selected input buffer into the output buffer.
SetMultiplexSource
Specifies the source buffer to copy through to the output buffer.
- BYTE Source
- BOOL ResetInputIndex
- 0=Leave Index, 1=Reset Index to 0
MultiplexArray
Passes an entire buffer through the multiplexer.
Simulation macro reference
Connect To 0
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Connect To 1
This property is of type Panel object and can be referenced with the variable name ConnectTo2.
Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name BuffSize.
Buffer Type
This property is of type Fixed list of ints and can be referenced with the variable name BuffType.
Sets the buffer data type.
Number of Inputs
This property is of type Fixed list of ints and can be referenced with the variable name NumInputs.
The number of inputs the multiplexer can switch between.
