Component: Output CSV (DSP)
Author | Matrix Ltd |
Version | 1.2 (Release) |
Category | DSP |
Output CSV component
Allows the values from a buffer to be output directly into a .CSV format file. Either a value at a time or as an array.
WriteArray
Writes a buffer of values from the selected DSP buffer to the CSV file.
FAT component must be initialised before calling this macro.
WriteValue
Writes a single value from the selected DSP buffer to the CSV file.
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
FAT Component
This property is of type Panel object and can be referenced with the variable name FATComponent.
Points to the FAT filesystem component to allow access to file system and embedded SD card.
Filename
This property is of type Line of text and can be referenced with the variable name Filename.
Name of the file to write DSP data to.
Layout
This property is of type Fixed list of ints and can be referenced with the variable name Layout.
Existing Data
This property is of type Fixed list of ints and can be referenced with the variable name ExtData.
Decides what to do when opening a file that already exists.
