Component: Rectifier (DSP)
Author | Matrix Ltd |
Version | 1.2 (Release) |
Category | DSP |
Rectifier component
Converts the negative elements of a signal into a mirrored positive signal.
ControlRectifier
Enables or disables the rectifier, enabled by default
- BOOL State
- 0=Disable, 1=Enable
Rectify
Collects a single value from the input buffer and outputs a rectified version of the value.
RectifyArray
Passes an entire buffer through the rectifier and outputs a rectified version of the buffer at the other end
Simulation macro reference
Connect To
This property is of type Panel object and can be referenced with the variable name ConnectTo.
Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name BuffSize.
Buffer Type
This property is of type Fixed list of ints and can be referenced with the variable name BuffType.
Sets the buffer data type.
Rectifier Threshold
This property is of type Signed integer and can be referenced with the variable name RectifyValue.
Value at which to choose to flip the signal.
Default 0 for a signed buffer.
