Ribbon Toolbar
Revision as of 11:55, 26 October 2020 by BenR (talk | contribs)
Introduction
The Flowcode environment consists of a main work area in which the flowchart windows are displayed, several toolbars that allow icon and components to be added to the flowchart application, windows that allow the status of the microcontroller and attached components to be viewed and windows that display variables and macro calls when the flow chart is being simulated.
From the View menu you are able to customise Flowcode to hide and display panel windows such as the Dashboard Panel, System Panel, Properties Panel, Component Debugger and much more, you can also show / hide the Toolbars referenced as Toolboxes, e.g. the 'Main Toolbar', 'Components Toolbar' or rather Toolbox, as well as the 'Icons Toolbar' otherwise known as the 'Command Toolbox'
Video instructions
See the Accessing and Arranging Flowcode Panels video to learn how to organize the application to your preference and manage your work space effectively for optimal productivity and ease of access.
Watch the Toolbars and Buttons video to learn how to use each toolbar effectively as well as learning specific details and functions of each toolbar button.
Finally, view the Tabbed Flowcharts and Macros video to see how to control the interface when managing macros, from tabbed flowcharts and macros to viewing two macro flowcharts on one screen.
FXa7LJsRvAs}} 9c6FIZTfGmA}}
{{#ev:youtube|c0d47BSkKS4}}
Icons Toolbar
Drag and drop Flowchart and State Diagram icons from the Command Icons toolbar onto the main flowchart window to create your flowchart application.
The Icons tab of the Project explorer window also contains Flowchart and State Diagram icons.
Components Toolbar
This toolbar displays the component libraries that can be included in your program. Click on a component and it can be added onto either the Dashboard Panel or the System Panel and will be automatically connected to the microcontroller in the Chip view.
The properties of the component such as Pin connections, Configuration Parameters and other settings can be edited using the Properties window.
View Toolbar
The following elements can be switched on and off using the view toolbar section of the main ribbon.
Chip View
The pins of the selected target microcontroller is displayed in this window.
When the flowchart is being simulated, the state of the microcontroller I/O ports are shown on the microcontroller as red and grey for high and low outputs respectively.
4) Flowchart Window
System Panel
5) System Panel
Dashboard Panel
6) Dashboard Panel
Project Explorer
7) Project Explorer
Icon Lists Pane
8) Icon Lists
9) Simulation Debugger
10) Main Toolbar
Use this command to display and hide the Toolbar, which includes buttons for some of the most common commands in Flowcode, such as 'Open' (File > Open), 'Print' (File > Print) as well as Compiling the flowchart to Chip, HEX and C. You can even control simulation by running, pausing and stopping simulation using this toolbar as stepping into and over icons to simulate step by step.
11) Status Bar
12) Zoom Level
Change History
Compiler Messages
