Component: UART Software (Timer) (Comms: Interface)
Revision as of 12:03, 2 December 2020 by BenR (talk | contribs) (XML import)
Author MatrixTSL
Version 1.0 (Release)
Category Comms: Interface
Image UART Software (Timer) component
Creates a reliable software UART that can be driven using a timer interrupt setup by the user. The timer interrupt must be interrupting at the required baud rate. e.g 9600Hz.
SendString
Sends an string to the transmit buffer
<- STRING Data
This parameter may be returned back to the caller
ReceiveArray
Gets an array of values from the receive buffer.
Returns number of values received.
UINT Values
UINT NumValues
UINT Timeout
Time in milliseconds to wait for data
UINT
SendArray
Sends an array of values to the transmit buffer
UINT Values
UINT NumValues
UART_Timer_Process
Called as part of a timer interrupt at the specific UART baud rate.
This macro has no parameters
ReceiveValue
Gets a single value from the receive buffer
UINT Timeout
UINT
SendValue
Sends a single value to the transmit buffer
UINT Value
CheckBuffer
Returns the number of values in the transmit or receive buffer
BOOL Buffer
0=Transmit / 1=Receive
UINT
ReceiveString
Gets a string from the receive buffer
UINT MaxChars
UINT Timeout
STRING
Initialises the UART component pins ready to send and receive data
Simulation macro reference
Data Bits
This property is of type Fixed list of ints and can be referenced with the variable name DataBits.
Stop Bits
This property is of type Fixed list of ints and can be referenced with the variable name StopBits.
Use TX
This property is of type True or false and can be referenced with the variable name UseTx.
Allows the Transmit pin to be enabled / disabled
Use RX
This property is of type True or false and can be referenced with the variable name UseRx.
Allows the Receive pin to be enabled / disabled
Transmit Pin
This property is of type Single digital pin and can be referenced with the variable name TXPin.
Pin assigned to transmitting data
Transmit Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name TXBufferSize.
Number of bytes that can be stored in the outgoing transmit buffer
Receive Pin
This property is of type Single digital pin and can be referenced with the variable name RXPin.
Pin assigned to receiving data
Receive Buffer Size
This property is of type Unsigned integer and can be referenced with the variable name RXBufferSize.
Number of bytes that can be stored in the incoming receive buffer
Injector
This property is of type Fixed list of ints and can be referenced with the variable name Injector.
