Component: Delay (DSP)
Revision as of 10:14, 10 March 2021 by BenR (talk | contribs)
Version 1.2 (Release)
Category DSP
Image Delay component
Allows an adjustable delay to be inserted into the DSP system
Here is a simple example file for the Delay component.
FC6 Icon.png Delay
The DelayADC component is used to set the amount of delay that the component provides 0-2550 samples in steps of 10 samples.
The Input ADC component is used to pass a variable value into the DSP chain to allow the delay to be simulated.
Here is a picture showing the scope response of the delay component.
DelayTick
Passes a single value from a buffer into the delay buffer and spits out a delayed value at the other end
This macro has no parameters
Delay
Passes an entire buffer into the delay buffer and spits out a delayed version of the buffer at the other end
SetDelaySize
Specifies the number of values in the delay buffer to allow the length of the delay to be adjustable during runtime.
UINT Delay_Count
Simulation macro reference
Max Delay Count
This property is of type Signed integer and can be referenced with the variable name max_delay.
The maximum number of values to delay the incoming signal by
Initial Delay Count
This property is of type Signed integer and can be referenced with the variable name initial_delay.
The initial delay that will be used at startup
Buffer Manager
This property is of type Fixed list of ints and can be referenced with the variable name buffer_manager.
Specifies the DSP system buffer manager
Input
This property is of type Fixed list of ints and can be referenced with the variable name input_a.
Specifies the buffer which is used as the input to the delay
Output
This property is of type Fixed list of ints and can be referenced with the variable name output_c.
Specifies the buffer which is used as the output to the delay
Sample Rate (Hz)
This property is of type Floating point and can be referenced with the variable name sample_rate.
Sample rate used to generate some useful calculations
Max Delay (s)
This property is of type Floating point and can be referenced with the variable name del_max.
Maximum possible delay in seconds at the specified sample rate
Initial Delay (s)
This property is of type Floating point and can be referenced with the variable name del_initial.
Initial delay in seconds at the specified sample rate
