Component: Property Manager (Storage )
Revision as of 13:49, 7 July 2021 by BenR (talk | contribs) (XML import)
Version 1.0 (Release)
Category Storage
Image Property Manager component
Allows property values exposed to the user to be saved and loaded using an external file. Simplifies the process of storing and retreiving the property values. Also works with nested properties using the "::" syntax.
This component does not contain any downloadable macros
Simulation macro reference
Save
Saves the registered property values to the config file.
This macro has no parameters
Load
Loads the registered property values from the config file.
RegisterProperty
Registers a property to be saved or loaded
<- STRING PropertyVariable
Property variable exposed to the user, highlight property and variable is shown at the bottom of the window.
This parameter may be returned back to the caller
Filepath
This property is of type Directory and can be referenced with the variable name CSV_ReadWrite1::Filepath.
Sets the path of the file to write to.
$(srcdir) default sets the path to be the same as the Flowcode project path.
Filename
This property is of type Line of text and can be referenced with the variable name Filename.
Show Dialogue On Load
This property is of type True or false and can be referenced with the variable name DialogueOnLoad.
Forces the user to check if they are sure before loading saved values.
Show Dialogue On Save
This property is of type True or false and can be referenced with the variable name DialogueOnSave.
Forces the user to check if they are sure before overwriting previous values.
