Component: Thermocouple ( MCP960X) (Environmental)
Author | Matrix TSL |
Version | 1.0 (Release) |
Category | Environmental |
Thermocouple ( MCP960X) component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
ReadReference_Int
Returns the Reference (IC die) temperature from the last sample as an integer value.
Use Sample first, which samples both reference & themocouple temperatures.
ReadReference_Float
Returns the reference (IC die) temperature from the last sample as a floating point.
Sample
Must be called before any of the Read functions.
Reads the memory of the MCP9600/1 IC. Returns 0 for 9600. Checks for errors, MCP9601 only.
Returns: 0 = OK, 1 = O/ C Themocouple & 2=S/C Themocouple.
ReadThermocouple_Int
Returns the thermocouple temperature from the last sample as an integer value.
ReadThermocouple_Float
Returns the thermocouple temperature from the last sample as a floating point value.
Configures the I2C bus ready for communications.
Simulation macro reference
Thermocouple Type
This property is of type Fixed list of ints and can be referenced with the variable name ThermocoupleType.
Thermocouple type.
Selects which type of thermocouple the IC works with.
Filter Coefficients
This property is of type Fixed list of ints and can be referenced with the variable name FilterCoef.
Digitial filter selection.
The higher the number the better the filter.
Results more stable but take longer to update.
Unit
This property is of type Fixed list of ints and can be referenced with the variable name Unit.
Select Temperature results to be celsius or fahrenheit
Address
This property is of type Unsigned integer and can be referenced with the variable name Address.
Address ranges 0x60 - 0x67 (96 - 103)
This property is of type Fixed list of ints and can be referenced with the variable name cal_i2c1::CHANNEL.
Channel selection
SDA
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SDA.
SCL
This property is of type Single digital pin and can be referenced with the variable name cal_i2c1::SCL.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
This property is of type True or false and can be referenced with the variable name cal_spi1::ConsoleData.
This property is of type True or false and can be referenced with the variable name cal_spi1::ScopeTraces.
API
This property is of type Fixed list of ints and can be referenced with the variable name cal_spi1::Injector.
