Bot test
Revision as of 15:31, 10 August 2021 by DavidA (talk | contribs)
Macro References
Fc9-comp-macro.png StringRead
Returns the ASCII value of character idx of the Response string.
Fc9-u8-icon.png - Byte idx
Needs to be a equal to or less than the string length of the response in order to retrieve a valid character.
Fc9-u8-icon.png - Byte Return
Fc9-comp-macro.png SendScript
Sends Script idx
Note that the general property Number of Scripts needs to be set so that it allows the scripts to be accessed and sent. Returns 0 for success and 1 for error
Refers to the Script page to send (1-4).
Fc9-comp-macro.png SendCommand
Sends the command buffer.
Returns 1 for success in sending the command. Returns 0 for errors.
Fc9-u8-icon.png - Byte ExpectEcho
Remote module automatically echos back data: 1 = On (Expect echo), 0 = off
Fc9-u8-icon.png - Byte SendCR
Automatically adds \n to the end of the command data: 1 = append CR, 0 = no CR.
Fc9-comp-macro.png CreateCommandString
Assigns a string of characters to the Command buffer.
Returns 1 for success in adding the characters to the buffer. Returns 0 for errors, including Buffer overflow.
Fc9-string-icon.png - String Data
This parameter may be returned back to the caller
Component Property Reference
Fc9-type-21-icon.png Command Buffer Size
Maximum number of bytes that can be stored in the outgoing command buffer.
Fc9-type-21-icon.png Response Buffer Size
Maximum number of bytes that can be stored in the incoming response buffer.
Fc9-type-16-icon.png Script Count
Controls how many AT scripts are stored into non-volatile memory
Fc9-type-21-icon.png Channel
UART Channel selector
Software channels are bit banged using generic I/O pins but are not as reliable as hardware channels. Hardware channels use the selected peripheral on-board the target microcontroller.
Fc9-type-5-icon.png TX
Fc9-type-5-icon.png RX
Fc9-type-16-icon.png Use Flow Control
Flow Control (Handshake) enable or disable.
On: Two I/O pins are used to control the flow of data in and out of the device. Off: Flow control is disabled.
Fc9-type-16-icon.png Baud Options
