Component: EEPROM (DS28E07) (Storage)
Revision as of 13:29, 18 August 2021 by BenR (talk | contribs) (XML import)
Author MatrixTSL
Version 1.0 (Release)
Category Storage
Image EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
SetString
Writes a string to the EE memory starting at the selected address.
All bytes from the string will be written including the null termination.
UINT Address
Address of the value to write
<- STRING Value
Data string to write
This parameter may be returned back to the caller
GetString
Gets a string from the specified start address.
UINT Address
Address of the first data byte
BYTE MaxLength
Maximum number of bytes in the string, also includes null termination byte
STRING
SetByteArray
Writes an array of bytes to the EE memory.
UINT Address
Starting address of the first value to write
BYTE Data
BYTE Count
Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
Writes a 16-bit value to the EE memory.
For consecutive 16-bit values the address must be incremented by 2.
UINT Address
UINT Value
16-bit value to write
BOOL MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier.
SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
<- STRING SerialNumber
48-bit Serial Number e.g. "32DF4A3C1901"
AddressNextDevice
Scans for the next connected device with a matching family code.
Goes through the device list generated by the ScanBus macro.
This macro has no parameters
GetSerialString
Gets the Serial String for the current addressed device.
STRING
SetLong
Writes a 32-bit value to the EE memory.
For consecutive 32-bit values the address must be incremented by 4.
UINT Address
ULONG Value
32-bit value to write
BOOL MSBFirst
GetFloat
Reads a 32-bit floating point value starting from the specified byte address.
For consecutive float values the address must be incremented by 4.
INT Address
The starting byte address
BOOL MSBFirst
FLOAT
GetLong
Reads a 32-bit value starting from the specified byte address.
INT Address
BOOL MSBFirst
ULONG
GetInt
Reads a 16-bit value starting from the specified byte address.
INT Address
BOOL MSBFirst
UINT
GetByteArray
Reads an array of bytes starting from the selected address.
UINT Address
Starting address of the first value to read
BYTE Data
Byte array to store incoming data
UINT Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
Writes a single byte to the EE memory.
UINT Address
BYTE Data
GetByte
Reads a single byte from the selected address.
UINT Address
Address of the value to read
BYTE
SetFloat
Writes a 32-bit floating point value to the EE memory.
UINT Address
FLOAT Value
Floating point value to write
BOOL MSBFirst
Configures each matching sensor on the bus with the specified conversion bits.
Simulation macro reference
One Wire Component
This property is of type Fixed list of ints and can be referenced with the variable name OneWireComp.
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
This property is of type Unsigned integer and can be referenced with the variable name EESize.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
No - We use the panel GUI to perform the simulation.
Yes - We use OneWire comms via an API to communicate with real hardware.
Number EE Devices
This property is of type Fixed list of ints and can be referenced with the variable name NumSensors.
Sens the number of sensors we can communicate with during simulation
Serial 0
This property is of type Line of text and can be referenced with the variable name Serial0.
Serial number for simulated one wire device
