Component: EEPROM (DS28E07) (Storage)
Author | MatrixTSL |
Version | 1.0 (Release) |
Category | Storage |
EEPROM (DS28E07) component
A rugged EEPROM allowing one or more devices to be addressed and accessed. Requires a One Wire component to perform the bus operations.
SetString
Writes a string to the EE memory starting at the selected address.
All bytes from the string will be written including the null termination.
- UINT Address
- Address of the value to write
- <- STRING Value
- Data string to write
GetString
Gets a string from the specified start address.
- UINT Address
- Address of the first data byte
- BYTE MaxLength
- Maximum number of bytes in the string, also includes null termination byte
SetByteArray
Writes an array of bytes to the EE memory.
- UINT Address
- Starting address of the first value to write
- BYTE Data
- BYTE Count
- Number of bytes to write to the EE memory, Range: 1 to 128 bytes
SetInt
Writes a 16-bit value to the EE memory.
For consecutive 16-bit values the address must be incremented by 2.
- UINT Address
- UINT Value
- 16-bit value to write
- BOOL MSBFirst
- 0: LSB is the first byte, 1: MSB is the first byte
AddressSpecificDevice
Starts a temperature conversion on a specific device using a hex string identifier.
SerialNumber parameter should be 12 characters and contain the 48-bit Serial.
- <- STRING SerialNumber
- 48-bit Serial Number e.g. "32DF4A3C1901"
AddressNextDevice
Scans for the next connected device with a matching family code.
Goes through the device list generated by the ScanBus macro.
GetSerialString
Gets the Serial String for the current addressed device.
SetLong
Writes a 32-bit value to the EE memory.
For consecutive 32-bit values the address must be incremented by 4.
- UINT Address
- ULONG Value
- 32-bit value to write
- BOOL MSBFirst
GetFloat
Reads a 32-bit floating point value starting from the specified byte address.
For consecutive float values the address must be incremented by 4.
- INT Address
- The starting byte address
- BOOL MSBFirst
GetLong
Reads a 32-bit value starting from the specified byte address.
- INT Address
- BOOL MSBFirst
GetInt
Reads a 16-bit value starting from the specified byte address.
- INT Address
- BOOL MSBFirst
GetByteArray
Reads an array of bytes starting from the selected address.
- UINT Address
- Starting address of the first value to read
- BYTE Data
- Byte array to store incoming data
- UINT Count
- Number of bytes to read from the EE memory, Range: 1 to 128 bytes
SetByte
Writes a single byte to the EE memory.
- UINT Address
- BYTE Data
GetByte
Reads a single byte from the selected address.
- UINT Address
- Address of the value to read
SetFloat
Writes a 32-bit floating point value to the EE memory.
- UINT Address
- FLOAT Value
- Floating point value to write
- BOOL MSBFirst
Configures each matching sensor on the bus with the specified conversion bits.
Simulation macro reference
One Wire Component
This property is of type Fixed list of ints and can be referenced with the variable name OneWireComp.
Link to the one wire component to host the bus.
EEPROM Size (Bytes)
This property is of type Unsigned integer and can be referenced with the variable name EESize.
The number of bytes of memory available on the device.
Simulate Comms
This property is of type True or false and can be referenced with the variable name SimComms.
No - We use the panel GUI to perform the simulation.
Yes - We use OneWire comms via an API to communicate with real hardware.
Number EE Devices
This property is of type Fixed list of ints and can be referenced with the variable name NumSensors.
Sens the number of sensors we can communicate with during simulation
Serial 0
This property is of type Line of text and can be referenced with the variable name Serial0.
Serial number for simulated one wire device
