Bot test
Revision as of 12:03, 31 August 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Version 2.0
Category Comms: System
DMX-512 Master component
A serial based communications protocol designed for controlling theatrical equipment such as dimmers, fog machines and intelligent lights. DMX-512 Slave devices are daisy chained together with a final 180R terminating resistor at the end of the chail. DMX requires the signal to be level shifted from VCC and GND to +2.5V and -2.5V.
DMX Master Example, reads the value of two ports using switch arrays to set the values and then transmits the data in a DMX packet.
FC6 Icon.png DMX Master Example1
DMX Slave Example, captures the first DMX data channel sent from the Master and outputs the value onto a Port using the LED array component.
FC6 Icon.png DMX Slave Example1
Fc9-comp-macro.png SetDataChannel
Sets the data byte in a data channel
Fc9-u16-icon.png - UINT Channel
Fc9-u8-icon.png - BYTE DataValue
Fc9-comp-macro.png SendDataChain
Transmits the BREAK, MAB and StartCode followed by the contents of the data channels.
Fc9-u8-icon.png - BYTE StartCode
Fc9-comp-macro.png Initialise
Configures the UART serial interface.
Fc9-type-16-icon.png Channel
Fc9-type-16-icon.png Baud Options
Fc9-type-5-icon.png TX
Fc9-type-21-icon.png Data Channels
Number of data bytes used by the DMX chain, Max 512 bytes per transmission. 24 Bytes minimum to match minimum 1204us timing requirements, not all channels need to be used.
Fc9-conn-icon.png Simulations
Fc9-type-21-icon.png Console Columns
Fc9-type-16-icon.png Data Source
