Component: XML JSON Parser (Runtime Tools)
Author | MatrixTSL |
Version | 1.0 (Release) |
Category | Runtime Tools |
XML JSON Parser component
A component designed to simplify the collection of data from XML and JSON sources. Parses the raw data and creates a dynamic representation of the data that is easy to navigate and interrogate. Also allows the objects to be manually created or edited and then re-exported as XML or JSON format.
XML Example
A simple example to read in an XML formatted file and extract data from the structure.
JSON Example
A simple example to read in an JSON formatted file and extract data from the structure.
This component does not contain any downloadable macros
Simulation macro reference
SetObjectString
Sets the data string of an existing object.
- HANDLE Object
- Handle to the object
- <- STRING Data
FindObject
Finds the first instance of an object.
Returns the first matching path from the root.
Returns 0 if the path was not found.
- <- STRING ObjPath
- e.g. "rss.channel.title"
GetRootHandle
Allows for user to step through the objects manually using the inbuilt runtime api calls.
FindObjectString
Searches for and then collects the data string from the specified path.
- <- STRING ObjPath
AddObject
Adds a tag at the selected location.
Use the GetRootHandle and runtime API Tree functions .
Returns the handle of the new object.
- HANDLE ParentObject
- The Object Handle to store the new tag inside
- <- STRING Tag
- Name of the object
- <- STRING Data
- data for the object (optional)
FindNextObject
Finds the next instance of an object following a GetObject* call.
Returns the first matching path from the last search.
- <- STRING SubObjPath
- e.g. "item.title"
ParseJSONDataString
Parses JSON formatted data in a piecemeal format as and when file data is available.
Creates objects to store the contents of the JSON
- <- STRING Data
- JSON Data string, can be a chunk of a file at a time
- UINT Length
- Number of Bytes to process
GetObjectString
Collects the data string from the specified object.
- HANDLE Object
ClearObjects
Deletes all object data ready for fresh input
GetObjectTag
Collects the tag string from the specified object.
- HANDLE Object
DeleteObject
Deletes a selected tag object.
- HANDLE Object
- BOOL : Returns true if the operation is a success, else false
FindNextObjectString
- e.g. "item.title"
SetObjectTag
Sets the tag name of an existing object.
- HANDLE Object
- <- STRING Tag
ParseXMLDataString
Parses XML formatted data in a piecemeal format as and when file data is available.
Creates objects to store the contents of the XML.
- <- STRING Data
- XML Data string, can be a chunk of a file at a time
- UINT Length
- Number of bytes to process
This component does not contain any properties
