Component: CAN (CAL) (Misc)
Author | Matrix TSL |
Version | 2.4 |
Category | Misc |
CAN component
CAL = Code Abstraction Layer - Allows one code base to run on a wide range of chips. Low level routines for controling the internal CAN peripheral.
SetRxMask |
Generic function to set Identifier. CAN registers will be configured depending upon Std/Ext mode setting. | |
mask |
id |
Return |
GetValue |
Get the Value of the Named property | |
Name |
Return |
GetRxData |
Returns the data byte at index from the buffer specified | |
buffer |
The index of the required buffer | |
index |
The index of the required data byte in the buffer | |
Return |
InitRXMask |
Initialization setting for RX Mask | |
Mask |
Mask Number (0 or 1) | |
Value |
Return |
SendBuffer |
Sends the contents of the buffer previously filled with Set_TX_... calls | |
Buffer |
Send buffer: 0 to,2 | |
Return |
InitRXFilter |
Initialization setting for RX Filter | |
Filter |
Value |
Return |
GetRxDataCount |
Returns the number of valid data bytes in the buffer | |
buffer |
Return |
Init |
Must be called at least once and after every Uninit call to enable the CAN instance | |
Return |
SetValue |
Set the Value of the Named property | |
Name |
Value |
Return |
SetRxFilter |
filter |
id |
Return |
SetTxIdent |
buffer |
id |
Return |
CheckRx |
Checks to see if any messages are available for 'Buffer' specified | |
Buffer |
Send buffer: 0 to 1 | |
Return |
InitRXConfig |
Initialization setting for RX Buffer Config | |
Buffer |
Buffer Number (0 or 1) | |
Value |
Config data byte | |
Return |
Uninit |
Uninitialises the CAN, freeing its connections for general use | |
Return |
GetList |
Get the Filter List of the Named Property | |
Name |
Return |
GetRxIdent |
Generic function to get the received message Identifier. | |
buffer |
Return |
