Component: RMT (Internal) (Misc)
Revision as of 16:13, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Misc
RMT (Internal) component
Provides access to the onboard remote control (RMT) peripheral allowing for high speed data input / output without requiring bit banging from the ESP32 processor.
Fc9-comp-macro.png SetBuffer
Writes data to the RMT buffer
Fc9-u16-icon.png - UINT Index
Array index, Range: 0 - (BufferSize - 1)
[[File:]] - State0
The first state to output
Fc9-u16-icon.png - UINT Length0
The length of the first output state in divided clock periods
[[File:]] - State1
The second state to output
Fc9-u16-icon.png - UINT Length1
The length of the second output state in divided clock periods
Fc9-comp-macro.png Transmit
Sends out the RMT data buffer.
Fc9-comp-macro.png Initialise
Initialises the RMT module ready for data to be sent or received.
Fc9-comp-macro.png SetValue
Sets the Value of the property PERIOD, PRESCALE or CHANNEL (if CHANNEL also updates the PORT from FCD)
Fc9-string-icon.png - STRING Name
Fc9-string-icon.png - STRING Value
Fc9-comp-macro.png SetDuty10Bit
Set the Duty Cycle for this PWM Channel. PIC/AVR - Range: 0-1023 16-bit PIC - Range: 0-65535
Fc9-u16-icon.png - UINT duty
Duty value 0 - 1023
Fc9-comp-macro.png GetList
Returns CHANNEL or PRESCALE list from the FCD and updates the internal property
Fc9-comp-macro.png InitRXConfig
Initialization setting for RX Buffer Config
Fc9-u8-icon.png - BYTE Buffer
Buffer Number (0 or 1)
Fc9-u8-icon.png - BYTE Value
Config data byte
Fc9-comp-macro.png Uninit
Uninitialises the CAN, freeing its connections for general use
Get the Filter List of the Named Property
Fc9-comp-macro.png GetRxIdent
Generic function to get the received message Identifier.
Fc9-u8-icon.png - BYTE buffer
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SetRxFilterStd
Sets the 16-bit filter as a bit-mask of the standard ID for received messages The messages are accepted if (StdID & Mask) == Filter
Fc9-u8-icon.png - BYTE Filter
Filter number
Fc9-u8-icon.png - BYTE Hi
The high byte (bits 8-15) of the ID
Fc9-u8-icon.png - BYTE Lo
The low byte (bits 0-7) of the ID
Fc9-comp-macro.png SetRxFilterExd
Sets the 32-bit filter as a bit-mask of the extended ID for received messages The messages are accepted if (ExtID & Mask) == Filter
Send filter: 0 to 3
Fc9-u8-icon.png - BYTE ID3
The high byte (bits 24-31) of the ID
Fc9-u8-icon.png - BYTE ID2
The mid-high byte (bits 16-23) of the ID
Fc9-u8-icon.png - BYTE ID1
The mid-low byte (bits 8-15) of the ID
Fc9-u8-icon.png - BYTE ID0
Fc9-type-16-icon.png Mode
Controls if we are transmitting or receiving data
Fc9-type-5-icon.png Pin
Pin to assign the RMT functionality
Fc9-type-21-icon.png Clock Divider
Base Clock speed is 80MHz. Div by 1 = 80MHz Div by 2 = 40MHz Div by 4 = 20MHz Div by 8 = 10MHz
Fc9-type-16-icon.png Mem Block Num
Starting RMT memory block
Number of values inside the data buffer, 64 = 1 Block A buffer size of 128 would consume two sequential blocks of memory. If starting at block 1 then you can have a maximum buffer size of 512 consuming all 8 blocks.
Fc9-type-7-icon.png TX Loop Enable
Allows the transmit buffer to be constantly looped.
Fc9-type-7-icon.png TX Carrier Enable
Enables a carrier frequency to be overlaid on the transmitted data
Fc9-type-7-icon.png TX Idle Output
When not transmitting should the Transmit pin be an active output?
Fc9-type-16-icon.png TX Idle Level
Sets the output state when idle.
Fc9-type-7-icon.png RX Filter Enable
Allows the receive data to be filtered.
Fc9-type-21-icon.png RX Idle Threshold
Sets the number of divided clock periods to detect when the receiver is idle. Pulses longer then this period will not be received.
Fc9-conn-icon.png Simulations
