Component: FCD helper (Matrix Tools)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.0 |
Category | Matrix Tools |
FCD helper component
A helper control to query the current Flowcode definition XML file.
GetStrListItem |
Gets a list item from a string index and a textual name Suitable for writing to a property filter Newline is added | |
Index |
Name |
Return |
GetIntListItem |
Gets a list item from an integer and a textual name Suitable for writing to a property filter Newline is added | |
Index |
Name |
Return |
SetRange |
Sets the min-max range to draw on the dial Used for setting the needle | |
[[File:]] - | Start |
[[File:]] - | End |
[[File:]] - | Return |
SetLabel |
Sets the label to draw in the center of the dial | |
Hi |
Lo |
Label to draw at the bottom | |
SetPivotPos |
Sets the position of the object the lever rotates around | |
[[File:]] - | PositionHandle |
A handle to the position of the depressed location | |
Return |
SetLatching |
Sets whether the button is depressed when the mouse is released | |
[[File:]] - | Enabled |
Return |
Unregister |
Removes the object to the list if present | |
[[File:]] - | Target |
Return |
SetMovementFor |
Sets the movement in units or PI/16 steps for the button | |
[[File:]] - | Move |
Movement to set to, default 4 | |
Return |
Properties |
Connections |
Simulations |
