Component: DALI Master (Comms: System)
Revision as of 16:53, 16 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Comms: System
DALI Master component
A serial based communications protocol designed for controlling lighting, specifically digitally controlled dimmable fluorescent ballasts. DALI requires the signals to be level shifted from VCC and GND to +9.5V - +25.5V and GND. The master component can addess up to 64 individual slaves & up to 16 groups.
DALI Master Example, reads the value of a keypad and sends out DALI commands based on the key pressed, 1 = switch on a slave's light, 2 = switch off a slave's light, 3 = read the slave's light level. FC6 Icon.png DALI Master Example1 DALI Slave Example, listens for DALI messages and checks that the group is correct before attempting to process the request and if required reply to the master. FC6 Icon.png DALI Slave Example1
Fc9-comp-macro.png ReceiveBackwardFrame
Attempts to receive an 8-bit reply 0 indicates timeout or no reply
Fc9-comp-macro.png TransmitForwardFrame
Send out a 16-bit frame consisting of the 8-bit address and data bytes. After sending the controller will attempt to receive If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Address byte
Fc9-u8-icon.png - BYTE Data
Data Byte
Fc9-comp-macro.png TransmitIndividualForwardFrame
Sends out an individual frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Individual Address 0-63
Fc9-u8-icon.png - BYTE Type
0 = Data, 1 = Command
Fc9-comp-macro.png TransmitGroupForwardFrame
Sends out a group frame containing address and data. After sending the controller will attempt to receive a reply. If a reply is detected then the Return value will equal to the reply. If no reply is detected then the Return value will be 0.
Group Address 0-15
Fc9-comp-macro.png Initialise
Configures the UART serial interface.
Fc9-comp-macro.png SegShowDigit
Displays a digit on the 7-seg display
Fc9-u8-icon.png - BYTE Digit
Which of the digits to change (0 - 3)
Fc9-u8-icon.png - BYTE Value
The value to display (0 - 9)
Fc9-u8-icon.png - BYTE DecimalPoint
Decides if the decimal point is lit
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
[[File:]] - type
A boolean to indicate command type: true to write data, false to write a command
Fc9-comp-macro.png ReadAnalogAsByte
Reads one of the analogue components as an byte value
0 = LDR, 1 = POT
Fc9-comp-macro.png ReadAnalogAsInt
Reads one of the analogue components as an Integer value
0 = LDR, 1 = POT
[[File:]] - Return
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-comp-macro.png SetLEDState
Sets the state of a single LED
Fc9-u8-icon.png - BYTE Port
0 = PortA, 1 = PortB
Fc9-u8-icon.png - BYTE LED
0 = LED0, 7 = LED7
Fc9-u8-icon.png - BYTE State
Must be called before any other CAN component macros to enable and initialise the CAN peripheral.
Fc9-type-5-icon.png TX Pin
Fc9-type-5-icon.png RX Pin
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
