Component: DSPBuffer (DSP)
Author | Matrix TSL |
Version | 1.0 |
Category | DSP |
DSPBuffer component
Creates a DSP buffer to be embedded into a DSP component to hold any output values.
Some examples containing the Input ADC component.
Prv_PutPropStr |
Idx |
Val |
Return |
Prv_PutConsole |
Idx |
[[File:]] - | Val |
Return |
get |
idx |
[[File:]] - | Return |
put |
idx |
[[File:]] - | val |
Return |
Prv_GetPropStr |
Idx |
Return |
Prv_GetConsole |
Idx |
IsPlaying |
Checks to see if the last played track is still playing | |
GetReplyByte |
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code. | |
Index |
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB | |
Return |
SkipTrack |
Jump to the next or previous track | |
[[File:]] - | Direction |
0=Next, 1=Previous | |
Return |
Initialise |
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros. | |
Return |
ReadAnalogAsInt |
Reads one of the analogue components as an Integer value | |
Channel |
0 = LDR, 1 = POT | |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
Properties |
Val |
Parent Name |
Buffer Size |
Buffer Type |
Data Recorder Trace |
Console |
Console Size |
Text |
Orientation |
Enabled |
Connections |
Simulations |
