Component: Deinterlace (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.2 |
Category | DSP |
Deinterlace component
Allows multiple output buffers to be deinterlaced from a single input buffer. Useful for decoding multiple buffer channels sent via communications or storage.
DeinterlaceArray |
Repeats the deinterlace function as many times as set in the data count property. | |
Return |
Deinterlace |
Outputs a single value to each of the connected output buffers from the input buffer. | |
Return |
SetHandle |
[[File:]] - | Handle |
Return |
IsPlaying |
Checks to see if the last played track is still playing | |
[[File:]] - | Return |
GetReplyByte |
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code. | |
Index |
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB | |
Return |
SkipTrack |
Jump to the next or previous track | |
[[File:]] - | Direction |
0=Next, 1=Previous | |
Return |
Initialise |
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros. | |
Return |
ReadAnalogAsInt |
Reads one of the analogue components as an Integer value | |
Channel |
0 = LDR, 1 = POT | |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
