Component: Offset (DSP)
Jump to navigationJump to searchAuthor | Matrix Ltd |
Version | 1.1 |
Category | DSP |
Offset component
Allows the values in a single buffer to be offset uniformly. Functions include: Add, Subtract
Calculate |
Performs the selected offset on a value from the input buffer and passes to the output buffer. | |
Return |
CalculateArray |
Performs the selected offset on an entire buffer. | |
Return |
SetOffset |
Sets the Offset to be used when calling the calculate function. | |
[[File:]] - | Offset |
Return |
ReadAverageArray |
Returns the average from the last "Decay" number of buffers. | |
Return |
ReadPeak |
Returns the highest value from the last "Decay" number of index locations. | |
[[File:]] - | Return |
ResetRecords |
Allows the peak and trough to be reset back to default values. | |
[[File:]] - | ResetPeak |
[[File:]] - | ResetTrough |
Return |
GetReplyByte |
Reads a single byte from the last reply. Each reply contains 4 bytes starting with the command code. | |
Index |
Range: 0-3 / 0=Command, 1=Feedback, 2=Data MSB, 3=Data LSB | |
Return |
SkipTrack |
Jump to the next or previous track | |
[[File:]] - | Direction |
0=Next, 1=Previous | |
Return |
Initialise |
Sets up the UART and does some housekeeping. Must be called before calling any of the other component macros. | |
Return |
ReadAnalogAsInt |
Reads one of the analogue components as an Integer value | |
Channel |
0 = LDR, 1 = POT | |
Start |
Startup routine required by the hardware device. Automatically clears the display after initialising. | |
Return |
SetLEDState |
Sets the state of a single LED | |
Port |
0 = PortA, 1 = PortB | |
LED |
0 = LED0, 7 = LED7 | |
State |
Return |
Initialise |
Must be called before any other CAN component macros to enable and initialise the CAN peripheral. | |
Return |
