Component: GPS (EB056, Generic NMEA) (Wireless)
Jump to navigationJump to searchAuthor | Matrix Ltd. |
Version | 2.1 |
Category | Wireless |
GPS (EB056, Generic NMEA) component
Component designed to process incoming NMEA style GPS data and convert into meaningful values such as longitude, lattitude, ground speed, UTC date and time. Also available in the form of the EB056 GPS E-block.
GPS Example File
GPS Example
Example should show the Latitude generated by the GPS injector as well as the system time in simulation or UTC time on hardware.
Example data provided by the GPS NMEA injector component
GPS tracking application using an Arduino and an SD card reader.
GPS Tracker
ReadGroundSpeed |
Returns the current ground speed. Only returns correct data if Log Ground Speed property is set to yes. | |
[[File:]] - | Return |
ReadNumberOfSatellites |
Returns the current detected number of satellites. Only returns correct data if Log Satellite Count property is set to yes. | |
Return |
ReadDilutionOfPrecision |
Returns the current dilution of precision. Only returns correct data if Log Dilution Of Precision property is set to yes. | |
CheckBufferOverflow |
Returns the state of the buffer - 0 = OK, 1 = BufferTooShort, 2 = ItemNotFound. Only returns correct data if Log Buffer Overflow Property is set to Yes. | |
Return |
ReadLongitude |
Returns the current longitude. Only returns correct data if Log Longitude property is set to yes. | |
ReadUTCTime |
Returns a segment of the current UTC Time. Only returns correct data if Log UTC Time property is set to yes. | |
Unit |
Specifies which segment to read - 'h', 'm', 's' | |
Return |
IsDataValid |
Returns the state of the incoming data - 0 = NotValid, 1 = Valid 255 = No GPS Data Received. | |
Return |
ReadHorizontalDilutionOfPrecision |
Returns the current horizontal dilution of precision. Only returns correct data if Log HDOP property is set to yes. | |
ReadAltitude |
Returns the current altitude. Only returns correct data if Log Altitude property is set to yes. | |
ReadCourseOverGround |
Returns the current course over ground. Only returns correct data if Log Course Over Ground property is set to yes. | |
ReadUTCDate |
Returns a segment of the current UTC Date. Only returns correct data if Log UTC Date property is set to yes. | |
Unit |
Specifies which segment to read - 'd', 'm', 'y' | |
Return |
ReadVerticalDilutionOfPrecision |
Returns the current vertical dilution of precision. Only returns correct data if Log VDOP property is set to yes. | |
ReadLatitude |
Returns the current latitude. Only returns correct data if Log Latitude property is set to yes. | |
Initialise |
Initialises the UART used to communicate with the GPS module. | |
Return |
CardPlayback |
Plays back a .Wav file audio stream from the card | |
Filename |
Return |
ReadMic |
Reads the microphone sensor 0 - 4095 | |
Return |
ReadSwitch |
Read the switch value | |
index |
0 (left) or 1 (right) | |
Return |
SampleAccel |
Samples the accelerometer 0 = no new data, 1 = new data available | |
Return |
Left |
Rotates the robot left - waits for the angle to be traversed before returning | |
Angle |
Angle to turn in degrees | |
Return |
LCDDrawPixel |
Allows a single pixel on the LCD to be set or cleared | |
X |
X Pixel 0-127 | |
Y |
Y Pixel 0-31 | |
State |
0=White (Off), 1=Black (On) | |
Return |
ServoSetPosition |
Allows one of the servo positions to be assigned | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
CardBitmap |
Displays a monochrome bitmap read from the card on the LCD | |
X |
Range 0-127 | |
Y |
Range 0-31 | |
Filename |
Return |
CardOpen |
Attempts to open an existing file on the SD card 255=Error, 1=File not found, 0=Open OK | |
Filename |
Return |
Forwards |
Drives the robot forwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
ReadBearing |
Reads the compass bearing based on the degrees clockwise from magnetic north. | |
GetConsoleHandle |
Gets the handle to the console allowing data displaying on the panel etc. | |
LCDDrawLine |
Allows a single pixel width line to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ServoAutoMoveToPosition |
Allows one of the servo positions to move gradually to a new position | |
Channel |
Range 0-3 | |
Position |
Range 0-255 | |
Return |
ReadAllValue |
Reads a single value stored from the read all command Index dictates which sensor value to read | |
Index |
0=SW, 1-8=IR, 9-10=Line, 11=Light, 12=Mic, 13-15=Accel | |
Return |
LCDBacklight |
Allows the LCD backlight brighntess to be adjusted | |
Intensity |
Range 0-100, 0=Off, 1=Min Brightness, 100=Max Brightness | |
Return |
LCDDrawRect |
Allows a rectangle to be drawn on the LCD | |
X1 |
X Pixel 0-127 | |
Y1 |
Y Pixel 0-31 | |
X2 |
X Pixel 0-127 | |
Y2 |
Y Pixel 0-31 | |
Return |
ReadLine |
Reads one of the IR line sensors 0-1 0=Left, 1=Right | |
index |
0=Left, 1=Right | |
Return |
ServoDisable |
Allows one of the servo outputs 0-3 to be disabled | |
Channel |
Range 0-3 | |
Return |
ServoEnable |
Allows one of the servo outputs 0-3 to be enabled | |
Channel |
Range 0-3 | |
Return |
CardReadByte |
Reads a byte from the currently open file. Starts at the beginning of the file and auto increments to the end | |
Return |
CardErase |
Attempts to delete an existing file on the SD card 255=Error, 1=File not found, 0=Delete OK | |
Filename |
Return |
CardWriteByte |
Appends a byte to the end of the currently open file | |
Data |
Return |
EncoderRead |
Reads one of the motor encoder counters. Approx 0.328296mm of travel per encoder unit. | |
index |
0=Left, 1=Right | |
Return |
SetMotors |
Sets the motor speeds without feedback Range -100 to 100 | |
[[File:]] - | Left |
[[File:]] - | Right |
Return |
Backwards |
Drives the robot backwards - waits for the distance to be traversed before returning | |
Distance |
Distance in mm | |
Return |
EncoderReset |
Resets the motor encoder counters | |
Return |
LCDVerbose |
Allows the LCD to automatically report the API commands as they get processed. Default - verbose on | |
State |
0=Off 1=On | |
Return |
SetProp |
Allows the COM port property to be set from a parent component. | |
PropName |
PropVal |
Return |
CardInit |
Attempts to startup the SD card 255=No Card, 254=Init Fail, 0=Init OK | |
Return |
GetProp |
Allows the property filter for the COM port list to be copied to a parent component. | |
PropName |
Return |
LCDClear |
Clears the LCD | |
Return |
