Component: PIR Motion (Grove 101020020) (101020020) (Light)
Revision as of 19:47, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Light
PIR Motion (Grove 101020020) component
PIR motion sensor component for digital output sensors. Simulates range sensitivity and output hold.
Fc9-comp-macro.png SampleSensor
Returns the state of the sensor. Activated if movement detected in the sensor range.
Fc9-comp-macro.png Initialise
Configures the I/O ready for the sensor to be sampled.
Fc9-comp-macro.png GetAverageInt
Function call to read the ADC as a full width average sample over time
Fc9-u8-icon.png - BYTE NumSamples
Fc9-u8-icon.png - BYTE DelayUs
Number of micro seconds in between taking each sample
Fc9-comp-macro.png GetVoltage
Reads the ADC as a direct voltage
[[File:]] - Return
Fc9-comp-macro.png GetInt
Blocking call to read the ADC at full bit depth
Fc9-comp-macro.png GetByte
Blocking call to read the ADC as a byte
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor.
Fc9-type-21-icon.png Sensitivity
Simulation range used to detect object
Fc9-type-21-icon.png Holding Count
Number of calls to SampleSensor to repeat active state, once triggered
Fc9-type-5-icon.png SIG Pin
Pin connected to the sensor element of the photo transistor
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png Sim Mode
