Component: IO Expander (PCF8575) (Comms: System)
Version | 1.0 |
Category | Comms: System |
IO Expander component
Provides 16 digital input/output pins arranged into 8-bit ports using a I2C bus connection. Up to eight expanders can be connected to the same I2C peripheral by means of three address pins. Supports the PCF8575 device allowing up to 8 expanders to be connected to the same I2C bus.
ReadPort |
Reads the current input value of the I/O pins. | |
Return |
WritePort |
Writes an output value to the IO pins | |
Value |
Value to write. Range 0-65535 | |
Return |
Initialise |
Return |
Initialise |
Enables the I²C hardware and performs some initialization. Should be called at the start of the program or at least before any of the other I²C functions are called. | |
Return |
Initialise |
Startup the I2C bus ready for communications. | |
Return |
Start |
Outputs a start condition onto the I²C bus. | |
Return |
Initialise |
Return |
Initialise |
Initialise the sensor configuration as set by the component properties. Sets the default intigration time and gain as well as enable the sensor. | |
Return |
