Component: Median 32 bit (Storage)
Version | 1.0 |
Category | Storage |
Median 32-bit component
Component to calulate the median from a set of sample data. Provides the signal whilst removing any spikes caused by noise or other intermittent data.
AddSample |
Adds a sample to the running buffer | |
Sample |
Return |
ReadMedian |
Return |
Initialise |
Return |
SendPolyPressure |
Sends a note press with an associated polyphonic pressure value. | |
Channel |
Note |
Pressure |
Return |
ReadData |
Idx |
Return |
SendPatch |
Channel |
Instrument |
Return |
SendChannelPressure |
Channel |
Pressure |
Return |
Initialise |
Initialises the MIDI component and sets up the UART. | |
Return |
CommsBaud |
Sets the Baud rate of the alt communications channel | |
Baud |
Range: 0-7 : 0=1200 / 7=115200 | |
Return |
LCDOptions |
Controls some of the LCD options | |
Foreground |
Range: 0-1 | |
Background |
Range: 0-1 | |
Transparent |
Range: 0-1 | |
Return |
ReadDigitalInput |
Reads a single digital input. | |
Channel |
Return |
PWMDuty |
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535 | |
Channel |
Range 0-5 | |
Duty |
Return |
LCDCursor |
Sets the cursor position for the MIAC display | |
X |
Range: 0-21 | |
Y |
Range: 0-4 | |
Return |
WriteTran |
Allows a single transistor output to be switched on or off. | |
Channel |
Range 1-4 | |
Value |
0 = Off, 1 = On | |
Return |
Initialise |
Return |
LCDClear |
Clears the MIAC display | |
Return |
