Component: Real Time Clock (MCP7940N) (Storage)
Revision as of 20:35, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Storage
Real Time Clock (MCP7940N) component
Serial (I2C) Real Time Clock component for MCP7940N device. When used with a MIAC project this component gives access to the internal RTC (if fitted, depending upon model) and the component properties will be automatically configured.
Fc9-comp-macro.png SetTime
Sets the time from a string HHMMSS
Fc9-string-icon.png - STRING Time
Fc9-comp-macro.png GetTime
Returns the time as a string HHMMSS
Fc9-comp-macro.png ReadRegister
Read and return the value of the RTC register at the given address
Fc9-u8-icon.png - BYTE address
Fc9-comp-macro.png SetDate
Sets the date from a string DDMMYY
Fc9-string-icon.png - STRING Date
Fc9-comp-macro.png GetDate
Returns the date as a string DDMMYY
Fc9-comp-macro.png WriteRegister
Write the given data value to the RTC register at the given address
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png Initialise
Initialises the component ready for I2C communications
Fc9-comp-macro.png ReceiveHexNumber
Attempts to receive a hex number as ASCII characters and convert back into a numeric value. Note this function will receive until a timeout or a none hexadecimal char is received, the none numeric char will be lost.
Fc9-u8-icon.png - BYTE Timeout
Max time in ms to wait in between bytes
[[File:]] - IgnoreData
0=Dont ignore any data, 1=Ignore any initial none numeric data
[[File:]] - Prefix
Look for prefix before receiving, 1=0xFF, 0=FF
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png SendBinary32Bit
Sends out a 32-bit binary value split across four bytes.
Fc9-u32-icon.png - ULONG Value
[[File:]] - MSBfirst
0=Least significant byte first, 1=Most significant byte first
Fc9-comp-macro.png SendBinaryFloat
Sends out a 32-bit binary floating point value split across four bytes.
[[File:]] - Value
Fc9-comp-macro.png ReceiveByteArray
Receives an array of bytes and returns the number of bytes received.
Fc9-u8-icon.png - BYTE Data
Array to store the incoming data
Fc9-u8-icon.png - BYTE NumBytes
Maximum number of bytes to try and receive
Max amount of time in ms to wait between bytes
Fc9-comp-macro.png ReceiveString
Attempts to receive a string of bytes from the UART interface.
Time to wait in milliseconds for valid data before returning, 0=Dont wait, 255=Wait forever.
Fc9-u16-icon.png - UINT NumBytes
The number of bytes to try and receive, ideally your string variable should have at least 1 more byte to store the null termination byte
Sets up the RS232 peripheral, must be called at the start of your program or at least before you start calling any other RS232 macros.
Fc9-comp-macro.png ReceiveChar
Attempts to receive a single packet from the UART interface.
[[File:]] - Return
Puts the RF module in data mode and attempts to receive a string of bytes from the RF connection.
Fc9-u8-icon.png - BYTE Length
Specifies the maximum number of bytes to try and receive
Specifies how many milliseconds to wait for valid data before returning.
Starts up and configures the RF module ready for use. The macro will return a value greater then 0 if the module has been started correctly, otherwise the macro will return a 0.
Sets up the 1-Wire output pin ready for communications.
Starts up the UART to allow communications and initialises the states of the various Modbus Coils, Inputs and Registers to 0.
Initialises the MIDI component and sets up the UART.
Fc9-comp-macro.png CommsBaud
Sets the Baud rate of the alt communications channel
Fc9-u8-icon.png - BYTE Baud
Range: 0-7 : 0=1200 / 7=115200
Fc9-comp-macro.png LCDOptions
Controls some of the LCD options
Fc9-u8-icon.png - BYTE Foreground
Range: 0-1
Fc9-u8-icon.png - BYTE Background
Range: 0-1
Range: 0-1
Fc9-comp-macro.png LCDVerbose
Controls the Verbose mode. When enabled the LCD automatically displays an account of the incoming API commands and parameters. When switched off the LCD is free for the user to control as required.
Fc9-u8-icon.png - BYTE Mode
Range: 0-1 : 0=Off or User Mode / 1=API Verbose Mode
Fc9-comp-macro.png ReadDigitalInput
Reads a single digital input.
Fc9-comp-macro.png PWMConfig
Sets the PWM configuration. Channel = 0 - 1 : 0 = EN_AB, A, B / 1 = EN_CD, C, D Period = 0 - 65535 Scaler = 0 - 3 : 0=1:1 1=1:8 2=1:64 3=1:256
Range 0-1
Fc9-u16-icon.png - UINT Period
Range: 0-65535
Fc9-u8-icon.png - BYTE Scaler
Range: 0-3
Fc9-comp-macro.png PWMEnable
Allows pulse width modulated transistor outputs to be switched on or off. Bit 0 = Enable AB Bit 1 = A / Bit 2 = B Bit 3 = C / Bit 4 = D Bit 5 = Enable CD
Fc9-u8-icon.png - BYTE EnableMask
Range 0-63 or 0b00000 to 0b111111
Fc9-comp-macro.png PWMDuty
Sets a single PWM channel duty. Channel = 0 - 5 : 0=EN_AB, 1=A, 2=B, 3=C, 4=D, 5=EN_CD Duty = 0 - 65535
Range 0-5
Fc9-u16-icon.png - UINT Duty
Fc9-comp-macro.png LCDCursor
Sets the cursor position for the MIAC display
Fc9-u8-icon.png - BYTE X
Range: 0-21
Fc9-u8-icon.png - BYTE Y
Range: 0-4
Fc9-comp-macro.png WriteTran
Allows a single transistor output to be switched on or off.
Range 1-4
Fc9-u8-icon.png - BYTE Value
0 = Off, 1 = On
Fc9-comp-macro.png LCDClear
Clears the MIAC display
Fc9-type-16-icon.png API
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-16-icon.png SDA Remap Pin
Fc9-type-5-icon.png SCL
Fc9-type-16-icon.png SCL Remap Pin
Baud rate to be used
Fc9-conn-icon.png Simulations
