Component: MULTIUART (SPI2UART) (Comms: System)
Version | 2.0 |
Category | Comms: System |
MULTIUART component
Uses a high speed SPI connection to enable up to four buffered external UARTs via the MULTIUART modules.
TransmitString |
Adds a byte to the transmit queue for the selected channel. | |
UART |
UART Index Range: 0-3 | |
Data |
Return |
SetBaud |
UART |
Baud |
0=1200, 1=2400, 2=4800, 3=9600, 4=19200, 5=38400, 6=57600, 7=115200 | |
Return |
TransmitByte |
UART |
Data |
Return |
CheckRx |
Returns the number of received bytes held in queue for the selected channel. | |
UART |
Return |
CheckTx |
Returns the number of bytes held in the transmit queue for the selected channel. | |
UART |
Return |
Initialise |
Activates the SPI peripheral and claims control over the I/O pins. | |
Return |
I2CRestart |
Put the I2C Module into Restart mode | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Return |
WIFIIsConnected |
Checks to see if the WIFI is active and connected | |
[[File:]] - | Return |
PWMDisable |
Disable a PWM output | |
Channel |
Range: 0-1 | |
Return |
I2CStart |
Put the I2C Module into Start mode | |
Channel |
Return |
SPITransfer |
Transfer a byte using the SPI bus | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
DataOut |
Return |
I2CReceive |
Receive a byte using the I2C bus | |
Channel |
[[File:]] - | Last |
Last byte to receive: Range 0-1 | |
Return |
I2CStop |
Put the I2C Module into Stop mode | |
Channel |
Return |
ServoDisable |
Disable a Servo output | |
Channel |
Range: 0-5 | |
Return |
SPIPrescaler |
Modify the speed of the SPI bus | |
Channel |
Prescaler |
Range: 0-2 | |
Return |
ServoEnable |
Enable a Servo output | |
Channel |
Range: 0-5 | |
Return |
ADCSample10 |
Reads the voltage present on an Alanog pin as an 10-bit value range 0-1023 | |
ADCChannel |
Range: 0-5 | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-17 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
ServoSetPosition8 |
Sets the position as an 8-bit value | |
Channel |
Range: 0-1 | |
Position |
Range: 0-255 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Return |
WIFIGetIP |
Gets the IP address of the board. Allows you to setup and get the assigned address via USB before using over WIFI, Use the WIFIIsConnected first to check the WIFI is active. | |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Prescaler |
Return |
PWMSetDuty8 |
Sets the duty for the PWM output | |
Channel |
Range: 0-1 | |
Duty |
Range: 0-255 | |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-1 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
