Component: Infrared Array AMG88xx (Light)
Revision as of 20:45, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray...")
Category Light
Infrared Array AMG88xx component
An 8x8 (64) Pixel infrared sensor array allowing basic none contact temperature detection.
Fc9-comp-macro.png SetMovingAverageMode
Set the moving average mode on or off.
[[File:]] - Mode
0 = Off, 1 = On
Fc9-comp-macro.png ClearInterrupt
Clear any triggered interrupts
Fc9-comp-macro.png SetInterruptMode
Set the interrupt to either absolute value or difference mode
[[File:]] - Mode
0 = Difference / 1 = Absolute
Allows the interrupt pin to be enabled or disabled.
[[File:]] - Mode
0 = Disabled / 1 = Enabled
Fc9-comp-macro.png SetInterruptLevels
Set the interrupt levels. Interrupt when going above High or interrupt when going below Low.
[[File:]] - High
Range: -1023 to 1023
[[File:]] - Low
[[File:]] - Hysteresis
Range: -1023 to 1023 ( Recommend 0.95 * High )
Fc9-comp-macro.png SamplePixels
Reads Infrared sensor values
Fc9-comp-macro.png ReadThermistor
Reads the onboard thermistor Returns the temperature in degrees Celsius as a floating point value
[[File:]] - Return
Fc9-comp-macro.png ReadPixel
Reads the temperature of a single pixel value from the last SamplePixels call.
Fc9-u8-icon.png - BYTE Index
Pixel to read. Range: 0 - 63
[[File:]] - Return
Fc9-comp-macro.png Initialise
Sets up the I2C interface and initialises the sensor.
Fc9-comp-macro.png I2CTransInit
Fc9-u8-icon.png - BYTE DeviceAddress
7-bit Device Address
Fc9-u8-icon.png - BYTE Baud
0=100KHz, 1=400KHz, 2=1MHz
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png I2CSend
[[File:]] - Return
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png PWMSetPrescaler
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-1
Range: 0-29
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png ADCSampleAverage10
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0, 3-7
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png OneWireReceiveByte
[[File:]] - Return
Fc9-comp-macro.png OneWireGetDeviceCount
Range: 0 - 11
Enable a PWM output
Range: 0-11
Fc9-comp-macro.png ADCSampleArray10
Range: 0, 3-7
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
Fc9-comp-macro.png ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
Range: 0, 3-7
Range: 1- 100
Fc9-type-21-icon.png Address
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
