Component: Accelerometer 3 Axis (LIS3LV02DQ) (Movement & Orientation)
Revision as of 20:45, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd. |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gra...")
Author Matrix Ltd.
Version 2.0
Category Movement & Orientation
Accelerometer 3-Axis component
LIS3LV02DQ Accelerometer sensor with options for I2C or SPI communications. Useful for approximating Pitch and Roll or for detecting acceleration. Also available in the form of the EB068 Accelerometer E-block.
Fc9-comp-macro.png SimReset1G
Resets the simulation to 0.0 on X and Y and 1.0 on Z as if the accelerometer was sitting completely horizontal.
Fc9-comp-macro.png Write_Register
Writes a data value to a specific register on the accelerometer
Fc9-u8-icon.png - BYTE Reg
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png CollectXYZData
Collect the data from the local accelerometer buffers. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Fc9-u8-icon.png - BYTE Axis
[[File:]] - Return
Fc9-comp-macro.png UpdateXYZData
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data
Fc9-comp-macro.png SimSetXYZ
Allows the XYZ slider values to be set via the simulation
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Fc9-comp-macro.png Initialise
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail.
Fc9-comp-macro.png ReadCompassCalibration
Allows one of the three compass calibration values to be read back. The Axis parameter specifies the Axis to be read. 0 / 'x' / 'X' - X axis 1 / 'y' / 'Y' - Y axis 2 / 'z' / 'Z' - Z axis
Axis Parameter
Fc9-comp-macro.png SimSetGyro
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Fc9-comp-macro.png UpdateAccelerometerData
Fc9-comp-macro.png SimSetCompass
[[File:]] - X
[[File:]] - Y
[[File:]] - Z
Fc9-comp-macro.png Read_Bearing
Reads the current sensor compass bearing based on degrees CW from magnetic north. Returns 0-359 where 0 = North, 90 = East, 180 = South, 270 = West Requires the ArcTan floating point function to be available to work correctly. Supported on AVR, 16-bit
Fc9-u8-icon.png - BYTE NumSamples
The number of readings to base the bearing on
Fc9-comp-macro.png IOSetOutputPin
Fc9-u8-icon.png - BYTE Pin
Range: 0-29
[[File:]] - State
Range: 0-1
Fc9-comp-macro.png ADCSampleAverage10
Fc9-u8-icon.png - BYTE ADCChannel
Range: 0, 3-7
Fc9-u8-icon.png - BYTE SampleCount
Range: 1- 100
Fc9-u8-icon.png - BYTE SampleDelay
Fc9-comp-macro.png OneWireScanBus
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found.
Fc9-comp-macro.png SPIInitialise
Fc9-comp-macro.png OneWireReceiveByte
Fc9-comp-macro.png I2CSend
[[File:]] - Return
Fc9-comp-macro.png UARTSend
Fc9-comp-macro.png OneWireGetDeviceCount
Fc9-comp-macro.png PWMSetPrescaler
Range: 0 - 11
Fc9-u8-icon.png - BYTE Period
Fc9-comp-macro.png PWMEnable
Enable a PWM output
Range: 0-11
Fc9-comp-macro.png ADCSampleArray10
Range: 0, 3-7
Range: 1- 32
Fc9-u16-icon.png - UINT SampleDelay
Fc9-u16-icon.png - UINT Samples
Fc9-comp-macro.png ADCSampleAverage8
Reads the voltage present on an Analog pin as an 8-bit value range 0-255 Performs the selected number of samples with the selected time in microseconds in between samples
Range: 0, 3-7
Range: 1- 100
The number of binary bits used to store the sensor's X,Y,Z readings.
Fc9-type-16-icon.png Bus Type
The interface used to talk to the accelerometer. I2C - Two Wire Interface SDA / SCL SPI - Four Wire Interface MISO / MOSI / SCK / CS
Fc9-type-16-icon.png Data Rate
Configures how often the sensor collects a new reading. More often = better instant reaction to new events Less often = more stable results
Fc9-type-16-icon.png Scale
The accelerometer readings are scaled based on the maximum amount of G force the sensor can represent. 6G = Bigger gravitational force 2G = Higher resolution
Fc9-type-16-icon.png Int Option
Sets if we use the interrupt pin to check if new data is available
Fc9-type-16-icon.png Power Option
Sets if the sensor is always powered or powered via a microcontroller output pin.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
SPI Channel selector
Fc9-type-16-icon.png Prescale
Prescale option selector
Fc9-type-5-icon.png MOSI
Fc9-type-5-icon.png MISO
Fc9-type-5-icon.png CLK
Fc9-type-5-icon.png CS / SS
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Coms
Yes: Accelerometer data will come from the simulation component sliders. No: Accelerometer data will come from the CAL component - I2C or SPI - API etc
