Component: Thermistor (EBM003) (EBM Modules)
Version | 1.1 |
Category | EBM Modules |
Thermistor component
A generic thermistor component that can be used to simulate and create code for any thermistor with a known temperature/resistance curve. Thermistor is connected in a simple potential divider circuit - thermistor between ADC input and 0V, and a fixed resistor between ADC and the positive supply. The component is also used with the EBM003 module, in which case the extra circuitry is already included. Default calibration is for the EBM003 module.
GetIntegerTemperature |
Reads the ADC input and returns the calculated Temperature as Integer degrees C | |
[[File:]] - | Return |
SetChannel |
Set the ADC Channel | |
[[File:]] - | ChannelID |
Return |
GetRealTemperature |
Reads the ADC input and Returns the calculated Temperature as Float value in degrees C | |
CalculateTemperature |
Converts the input ADC value and returns the Temperature in tenths of degree C | |
ADCValue |
ADC Reading to be converted | |
GetADCValue |
Returns the Raw ADC value from the Analogue Channel | |
Return |
GetHumidityReal |
Gets the real number portion of the humidity returned by calling SampleSensor. If humidity is 15.8 % then this function would return 8. | |
SampleSensor |
Communicates with the DHT22 sensor and receives the temperature and humidity readings. Returns 0 for success, 1 for no communication detected and 2 for checksum error. | |
Return |
GetTempFloat |
Gets the temperature returned by calling SampleSensor as a floating point number. If temperature is 15.8 degrees C then this function would return 15.8. | |
Initialise |
Initialise the sensor configuration as set by the component properties | |
Return |
Initialise |
Stes up the I2C bus and initialises the termperature sensor ready for use. | |
Return |
SimSetGyro |
Allows the XYZ slider values to be set via the simulation | |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
UpdateAccelerometerData |
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Return |
SimSetCompass |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
Initialise |
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-29 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
OneWireScanBus |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
Return |
OneWireReceiveByte |
Receives a byte from the one wire bus a bit at a time | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
OneWireGetDeviceCount |
Returns the number of devices found by the last ScanBus operation. | |
Channel |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Channel |
Range: 0 - 11 | |
Prescaler |
Period |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-11 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
