Component: Touch Pads (EBM013) (EBM Modules)
Version | 1.0 |
Category | EBM Modules |
Touch Pads component
This board provides two touch areas for use with capacitive sensing. Hence two digital touch switches can be implemented. This component directly interfaces with the EBM013 Sensors board.
Sample program using the EBM013 - Touch Pads sensor.
Sensors are first calibrated and then can be read as digital switches
Initialise |
Initialise the component. Returns 0 if successful | |
Return |
Initialise |
Set up the thermocouple sensor ready for use. | |
Return |
Initialise |
Initialise the sensor configuration as set by the component properties | |
Return |
Initialise |
Stes up the I2C bus and initialises the termperature sensor ready for use. | |
Return |
SimSetGyro |
Allows the XYZ slider values to be set via the simulation | |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
UpdateAccelerometerData |
Reads from the accelerometer and updates the local XYZ variables. Returns 1 for new data and 0 for no new data | |
Return |
SimSetCompass |
[[File:]] - | X |
[[File:]] - | Y |
[[File:]] - | Z |
Return |
Initialise |
Sets up up the communication bus and initialises the accelerometer module. Returns 0 for success and > 0 for fail. | |
Return |
IOSetOutputPin |
Sets the selected digital pin to an output and assigns the output state. | |
Pin |
Range: 0-29 | |
[[File:]] - | State |
Range: 0-1 | |
Return |
UARTReceive |
Receives a data byte from the UART. Recommend calling the UARTCheckRx function first to ensure data is available. | |
Channel |
Channel Index: Range 0 - UART Bus Count - 1 | |
Return |
OneWireScanBus |
Scans the one wire bus to detect all connected devices. Returns the number of one wire devices found. | |
Channel |
Channel Index: Range 0 - I2C Bus Count - 1 | |
Return |
SPIInitialise |
Initialsie the SPI module ready for communications | |
Channel |
Channel Index: Range 0 - SPI Bus Count - 1 | |
Return |
OneWireReceiveByte |
Receives a byte from the one wire bus a bit at a time | |
Channel |
Return |
I2CSend |
Transmit a byte using the I2C bus | |
Channel |
DataOut |
[[File:]] - | Return |
UARTSend |
Send a byte via the UART module | |
Channel |
Data |
Data Byte to send. Range: 0-255 | |
Return |
OneWireGetDeviceCount |
Returns the number of devices found by the last ScanBus operation. | |
Channel |
Return |
PWMSetPrescaler |
Sets the prescaler for the PWM output | |
Channel |
Range: 0 - 11 | |
Prescaler |
Period |
Return |
PWMEnable |
Enable a PWM output | |
Channel |
Range: 0-11 | |
Return |
Initialise |
Initialise the comms to the Arduino board ready for commands to be sent. | |
Return |
Properties |
Channel 1 |
ADC Channel number | |
Channel 2 |
On Value |
Off Value |
On Value |
Off Value |
Connections |
Simulations |
