Component: Temp / Humidity (SHT21) (Environmental)
Revision as of 20:46, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix TSL |- | width="20%" style="color:gray;" | Version | 2.0 |- | width="20%" style="color:gray...")
Version 2.0
Category Environmental
Temp / Humidity component
Humidity and temperature sensor using an SHT21 IC connected via I2C. On screen GUI allows temperature and humidity values to be simulated, and will show all I2C communication in a console window.
Fc9-comp-macro.png GetTemperatureReal
Return temperature reading as a float value in degrees C
[[File:]] - Return
Fc9-comp-macro.png GetTemperatureData
Returns the raw register pair value
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
[[File:]] - Return
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityData
Fc9-type-16-icon.png Channel
Channel selection
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Baud rate to be used
Fc9-type-16-icon.png API
Fc9-conn-icon.png Simulations
Fc9-type-7-icon.png Simulation Comms
