Component: LTSR Current Transducer (Electrical)
Revision as of 20:47, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | medelec35 |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray;...")
Author medelec35
Category Electrical
LTSR Current Transducer component
LTSR rage of +/- 6, 15 & 25A current Tranducers
Fc9-comp-macro.png Current
[[File:]] - Return
Fc9-comp-macro.png GetTemperatureData
Returns the raw register pair value
Fc9-comp-macro.png GetTemperatureInt
Return temperature reading as an integer value in degrees C
[[File:]] - Return
Fc9-comp-macro.png GetHumidityInt
returns the relative Humidity reading as an integer value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityReal
returns the Humidity reading as a float value
[[File:]] - Return
Fc9-comp-macro.png GetHumidityData
Fc9-comp-macro.png Initialise
Configures the I2C peripheral and puts the sensor into one shot mode ready to be sampled. Must be called before calling any of the other component macros. Returns 1 if the sensor has been intialised correctly, else returns 0.
Fc9-type-16-icon.png Device
Fc9-type-15-icon.png VDD
Fc9-type-6-icon.png Channel
Fc9-conn-icon.png Simulations
