Component: Thermocouple ( MCP960X) (Environmental)
Version | 1.1 |
Category | Environmental |
Thermocouple component
Component to interface the MCP960X IC from Microchip. Uses a standard 2-wire I2C interface to connect to the IC and collect the temperature. IC available in different versions to suit different thermocouple types.
Here is a basic example to display both the thermocouple temperature and IC surface temperature.
Sim Demo
ReadReference_Int |
Returns the Reference (IC die) temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
[[File:]] - | Return |
ReadRawDataADC |
Returns the thermocouple temperature from the last sample as an integer value in Degrees C. | |
ReadReference_Float |
Returns the reference (IC die) temperature from the last sample as a floating point. Use Sample first, which samples both reference & themocouple temperatures. | |
ReadRegister |
Reads a byte from a register | |
Address |
Return |
ReadThermocouple_Int |
Returns the thermocouple temperature from the last sample as an integer value. Use Sample first, which samples both reference & themocouple temperatures. | |
WriteRegister |
Writes a byte to a register | |
Address |
Data |
Return |
Initialise |
Configures the I2C bus ready for communications. | |
Return |
Initialise |
Configures each matching sensor on the bus with the specified conversion bits. | |
Return |
WriteRegister |
A simple example showing a generic way to write a register using I2C. | |
Address |
Data |
Return |
Initialise |
