Component: RFID (Sparkfun Quiic / ID 12LA) (15209) (Wireless)
Author | Matrix TSL |
Version | 1.0 |
Category | Wireless |
RFID (Sparkfun Quiic / ID-12LA) component
Provides functions to drive the Sparkfun Quiic RFID reader module (ID-12LA). Allowing access to read 125KHz RFID tags. Suitable for applications such as tracking, logging or access control.
RemoveCurrentTag |
Removes the current Tag ID from the known tag storage. | |
Return |
StoreCurrentTag |
Stores the current detected tag as a known tag storage Returns true if the tag has been stored or false if there is no remaining room | |
[[File:]] - | Return |
GetTagString |
Gets the tag ID returned as a string. Must be called after CheckForTag has returned true. String variable should be at least 13 characters long. | |
Return |
RemoveTagID |
Removes a specific 6-byte tag ID from the known tag storage | |
ID |
Array of 6 bytes containing tag ID | |
Return |
GetTimeMS |
Gets the time in milliseconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
Return |
GetTimeS |
Gets the time in seconds since the tag was read by the module. Must be called after CheckForTag has returned true. | |
Return |
CheckForTag |
Checks to see if a tag has been detected by the module. Returns 1 if tag has been detected. Tag ID and Time since read can be accessed using GetTag and GetTime macros. | |
GetTag |
Gets the tag ID returned as a byte array. Must be called after CheckForTag has returned true. Byte array variable should be at least 6 bytes long. | |
Data |
Return |
IsKnownID |
Checks to see if the last tag read by CheckForTag is saved into memory. Returns true if tag is stored in memory. | |
Initialise |
Initialises the I2C bus ready for communications with the module. Wipes the tag ID storage ready for data to be stored. | |
Return |
