Component: IButton (DS1990) (Storage)
Revision as of 20:58, 16 November 2021 by Wiki bot (talk | contribs)
Author MatrixTSL
Category Storage
IButton (DS1990) component
A rugged 48-bit unique identifier allowing for unique codes for logistical tracking or device identifiers etc. Compatible with the DS1990A and DS1990R iButton devices. Requires a One Wire component to perform the bus operations.
Fc9-comp-macro.png GetSerialString
Gets the Serial String for the current addressed device.
Fc9-comp-macro.png AddressNextDevice
Scans for the next connected device with a matching family code. Goes through the device list generated by the ScanBus macro.
Fc9-comp-macro.png Initialise
Configures each matching sensor on the bus with the specified conversion bits.
Fc9-comp-macro.png SetLong
Writes a 32-bit value to the EE memory. For consecutive 32-bit values the address must be incremented by 4.
Fc9-u16-icon.png - UINT Address
Address of the value to write
Fc9-u32-icon.png - ULONG Value
32-bit value to write
[[File:]] - MSBFirst
0: LSB is the first byte, 1: MSB is the first byte
Fc9-comp-macro.png GetFloat
Reads a 32-bit floating point value starting from the specified byte address. For consecutive float values the address must be incremented by 4.
[[File:]] - Address
The starting byte address
[[File:]] - Return
Fc9-comp-macro.png GetLong
Reads a 32-bit value starting from the specified byte address. For consecutive 32-bit values the address must be incremented by 4.
[[File:]] - Address
Fc9-u32-icon.png - ULONG Return
Fc9-comp-macro.png GetInt
Reads a 16-bit value starting from the specified byte address. For consecutive 16-bit values the address must be incremented by 2.
[[File:]] - Address
Fc9-comp-macro.png GetByteArray
Reads an array of bytes starting from the selected address.
Starting address of the first value to read
Fc9-u8-icon.png - BYTE Data
Byte array to store incoming data
Fc9-u16-icon.png - UINT Count
Number of bytes to read from the EE memory, Range: 1 to 128 bytes
Fc9-comp-macro.png SetByte
Writes a single byte to the EE memory.
Reads a single byte from the selected address.
Address of the value to read
Fc9-comp-macro.png SetFloat
Writes a 32-bit floating point value to the EE memory. For consecutive float values the address must be incremented by 4.
[[File:]] - Value
Floating point value to write
Fc9-type-16-icon.png One Wire Component
Link to the one wire component to host the bus.
Fc9-type-16-icon.png Number Devices
Sens the number of sensors we can communicate with during simulation
Fc9-type-10-icon.png Serial 0
Serial number for simulated one wire device
Fc9-conn-icon.png Simulations
No - We use the panel GUI to perform the simulation. Yes - We use OneWire comms via an API to communicate with real hardware.
