Component: Serial EEPROM (24C32) (Storage)
Revision as of 20:58, 16 November 2021 by Wiki bot (talk | contribs)
Version 2.2
Category Storage
Serial EEPROM (24C32) component
Serial (I2C) EEPROM component for 24C32 Can be added to a MIAC project to give read and write access to the internal non-volatile memory device (if fitted, depending upon model).
Fc9-comp-macro.png Read
Read and return the value of the EEPROM at the given address
Fc9-u16-icon.png - UINT address
Fc9-comp-macro.png Write
Write the given data value to the EEPROM at the given address
Fc9-u8-icon.png - BYTE data
Fc9-comp-macro.png WritePage
Fc9-u8-icon.png - BYTE count
Range: 1-128
Fc9-comp-macro.png GetDate
Collects the day of the month as a numeric value in the range of 1 - 31.
Fc9-comp-macro.png SetTimeServer
Overwrites the default time server setting allowing for multiple time servers to be queried.
Fc9-string-icon.png - STRING TimeServer
e.g. "pool.ntp.org"
Fc9-comp-macro.png GetMonth
Collects the month as a numeric value in the range of 1 - 12.
Fc9-comp-macro.png Initialise
Configures the timeserver variable as well as sets the timezone offset in seconds.
Fc9-comp-macro.png SetUTCOffset
Allows the UTC Offset to be defined in seconds. e.g. for BST use 3600 or for UTC+2 use 7200 or for UTC-2 use -7200
[[File:]] - UTCOffset
Time offset in seconds
Configures each matching sensor on the bus with the specified conversion bits.
Fc9-type-16-icon.png Device Address
Device address bits, these must match the address pins on the EEPROM IC.
Fc9-type-16-icon.png Channel
Channel selection
Baud rate to be used
Fc9-type-5-icon.png SDA
Fc9-type-5-icon.png SCL
Fc9-conn-icon.png Simulations
Fc9-type-16-icon.png API
