Component: String Initialiser (Storage)
Revision as of 20:58, 16 November 2021 by Wiki bot (talk | contribs)
Category Storage
String Initialiser component
A component allowing an easy way to initialise string variables using ROM memory. A simple and efficient way to populate string variables helping to save on RAM usage. Allows up to 16 strings to be stored. For additional strings simply use more String Initialiser components.
Fc9-comp-macro.png GetString
Gets a string stored in ROM memory and loads into a RAM string variable
Fc9-u8-icon.png - BYTE Index
Range: 0-15 Depending on number of strings
Fc9-comp-macro.png ReadDataByte
Reads a single data byte from the specified address.
Fc9-u16-icon.png - UINT PageAddress
Address bits A23-A8 : 16-bit Address - Range 0x0000 - 0xFFFF
Fc9-u8-icon.png - BYTE ByteAddress
A7-A0 : 8-bit Address within the page - Range 0x00 - 0xFF
Fc9-comp-macro.png ReadUniqueID
Reads the 8-byte unique identifier from the IC. Useful if you need each board to have it's own guarenteed unique address or identifier.
Fc9-u8-icon.png - BYTE ID
8-Byte data array to store the unique ID read back from the IC.
Fc9-comp-macro.png WriteDataArray
Writes an array of data bytes atarting at the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly. Note that all bytes will be written to the same page.
Fc9-u8-icon.png - BYTE Count
Number of bytes to write.
Fc9-u8-icon.png - BYTE Data
Fc9-comp-macro.png EraseChip
Erases all data stored on the chip. Chip erase takes between 20 seconds and 100 seconds to complete. Blocking mode is recommended to ensure write cycle is complete.
[[File:]] - Blocking
Controls if the macro blocks until the erase cycle is complete. 0 = Don't Wait, 1 = Wait
Fc9-comp-macro.png WriteDataByte
Writes a single data byte to the specified address. Writes must be enabled and memory locations must be erased for data writes to function correctly.
Data byte to write
Fc9-comp-macro.png EraseBlock
Erases a block of data stored on the chip. Erase takes between 45 milliseconds and 2000 milliseconds to complete. Blocking mode is recommended to ensure write cycle is complete.
Fc9-u8-icon.png - BYTE EraseMode
0=4KB / 1=32KB / 2=64KB
Fc9-comp-macro.png ReadDataArray
Reads up to 256 data bytes starting from the specified address. Note that all bytes will be read from the same page.
Number of bytes to read.
Byta array to store the incoming read data.
Fc9-comp-macro.png Initialise
Initialises the SPI bus ready for communications.
Configures each matching sensor on the bus with the specified conversion bits.
Fc9-type-16-icon.png Number of Strings
Fc9-type-10-icon.png String 0
String data index 0
Fc9-type-10-icon.png String 1
String data index 1
Fc9-conn-icon.png Simulations
