Component: Library Component (Misc)
Revision as of 20:59, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | MatrixTSL |- | width="20%" style="color:gray;" | Version | 1.0 |- | width="20%" style="color:gray;...")
Author MatrixTSL
Category Misc
Library Component component
A simple library component designed to create a panel presence for any components that don't need or have a graphical simulation. Compatible with linking icons.
Fc9-comp-macro.png FlashRx
Flashes the receive icon for a set period of time. Automatically clears the icon once time period is up.
Fc9-comp-macro.png FlashTx
Flashes the transmit icon for a set period of time. Automatically clears the icon once time period is up.
Fc9-comp-macro.png SetConsoleHandle
Sets the link to the component console allowing for click through and for panel console viewer linkage.
[[File:]] - Handle
Fc9-comp-macro.png ARB3DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB3.
Fc9-comp-macro.png PER
Sets the waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms)
[[File:]] - Period
Duration of the waveform period in seconds (20ns - 1Ms).
Fc9-comp-macro.png BEEPMODE
Set beep mode to; 0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR.
Fc9-u8-icon.png - BYTE Mode
Sets the beep mode (0 = ON, 1 = OFF, 2 = WARN, 3 = ERROR).
Fc9-comp-macro.png SWPTRGSRC
Sets the sweep trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
Fc9-u8-icon.png - BYTE Source
Set the sweep trigger source (0 = INT, 1 = EXT, 2 = MAN).
Fc9-comp-macro.png PULSPER
Sets the pulse waveform period to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
[[File:]] - Period
Duration of the pulse waveform period (20ns - 1Ms).
Fc9-comp-macro.png ARBDEF
Sets user specified waveform name <cpd2> and waveform point interpollation state <cpd3> of arbitrary waveform memory location <cpd1>.
Fc9-string-icon.png - STRING Name
Specified waveform name
Fc9-string-icon.png - STRING State
Waveform interpolatino state
Fc9-string-icon.png - STRING Location
Waveform memory location
Fc9-comp-macro.png WAVELVL
Sets the output waveform level to <nr1> %. (Lower limit: 50 - Upper limit: 100)
[[File:]] - Percent
Sets the output waveform level in percent (50 - 100).
Fc9-comp-macro.png CALVALRet
Returns the value from level calibration steps.
Fc9-comp-macro.png SWPENDFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz.)
[[File:]] - Frequency
Set the sweep end frequency in Hertz(Hz) (1uHz - 50MHz).
Fc9-comp-macro.png ZLOAD
sets the output load, which the generator is to assume for amplitude and dc offset entries, to; 0 = OPEN or 1 - 10,000
[[File:]] - Output
Sets the output load for amplitude and dc offset entires (0 = OPEN or 1 -10,000).
Fc9-comp-macro.png MODFMSHAPE
Sets FM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Fc9-u8-icon.png - BYTE Shape
Sets FM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png AMPLRNG
Sets the amplitude range to; 0 = AUTO, 1 = HOLD.
[[File:]] - Range
Sets the amplitude range (0 = AUTO, 1 = HOLD).
Fc9-comp-macro.png SYNCOUT
Sets the sync output to; 0 = ON, 1 = OFF.
[[File:]] - Sync
Enable/disable sync output (0 = ON, 1 = OFF).
Fc9-comp-macro.png SRE
Set the Service Request Enable Register to <nrf>.
Fc9-u8-icon.png - BYTE Status
Fc9-comp-macro.png ARB1Ret
Returns the binary-data from an existing abbitrary wavefrom memory location.
Fc9-comp-macro.png ARB2DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB2.
Fc9-comp-macro.png FREQ
Set the waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Sets the waveform frequency in Hertz(Hz) (1uHz - 50MHz).
Fc9-comp-macro.png PULSFALL
Sets the pulse waveform negative edge to <nrf> micro seconds. (Lower limit: 5ns - Upper limit: 99.9ns).
[[File:]] - Fall
Sets the pulse waveform negative edge in micro seconds (5ns - 99.9ns).
Fc9-comp-macro.png DCOFFS
Sets the dc offset to <nrf> Volts. (Lower limit: -4.500 Vdc - Upper limit: 4.500 Vdc).
[[File:]] - DCOffset
Sets the dc offset in Volts(Vdc) (4.500 Vdc - 4.500 Vdc).
Fc9-comp-macro.png PRE
Sets the Parallel Port Enable Register to the value <nrf>.
Set register value 0-255
Fc9-comp-macro.png CALIBRATION
Sets the calibration mode to <START>, <SAVE>, or <ABORT>. <nrf> represents the calibration password.
0 = START, 1 = SAVE, 2 = ABORT
Fc9-u32-icon.png - ULONG Password
Calibration password
Fc9-comp-macro.png SWPMKRFREQ
Sets the sweep marker to <nrf> Hz. (Lower limit: 10kHz - Upper limit: 100kHz).
Set the sweep marker in Hertz(Hz) (10kHz - 100kHz).
Fc9-comp-macro.png MODAMSRC
Sets AM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets AM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png AMPUNIT
Sets the amplitude units to; 0 = VPP, 1 = VRMS, 2 = DBM.
Fc9-u8-icon.png - BYTE Units
Sets the amplitude units (0 = VPP, 1 = VRMS, 2 = DBM).
Fc9-comp-macro.png ESRRet
Returns the value in the standard event status register in <nr1>
Fc9-comp-macro.png QERRet
Query and clear error register
Fc9-comp-macro.png SWPTIME
Sets the sweep time to <nrf> seconds
[[File:]] - Seconds
Set the sweep time in seconds.
Fc9-comp-macro.png MODHOPFREQ
Sets HOP frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Sets HOP frequency in Hertz(Hz) (1uHz - 50MHz).
Fc9-comp-macro.png PULSWID
Sets the pulse waveform width to <nrf> sec. (Lower limit: 20ns - Upper limit: 1Ms).
[[File:]] - Seconds
Sets the pulse waveform width in seconds (20ns - 1Ms).
Fc9-comp-macro.png PRERet
Returns the value in the Parallel Poll Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
Sets the amplitde to <nrf> in the units as specified by the AMPUNIT command. (Range = 10mVpp - 10Vpp)
[[File:]] - Amplitude
Sets the amplitude (10mVpp - 10Vpp). Units specificied by AMPUNIT command.
Fc9-comp-macro.png MODPOLFSK
Sets FSK trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set FSK trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png PULSEDGE
Sets the pulse waveform edges (positive and negative edge) to <nrf> micro Sec. Value zero sets to the minimum value allowed (Lower limit: 5ns - Upper limit: 40us).
[[File:]] - Edges
Sets the pulse waveform edges in micro seconds (5ns - 40us).
Fc9-comp-macro.png ARB4Ret
Fc9-comp-macro.png ARBLOAD
<cpd> sets the output waveform type to <DC>,<SINC>, <EXPRISE>,<LOGRISE>,<RAMPUP>,<RAMPDN>, <TRIANG>,<SQUARE>, <ARB1>,<ARB2>,<ARB3>, <ARB4>, <"USERNAME1">, <"USERNAME2">, <"USERNAME3">, <"USERNAME4">.
Fc9-string-icon.png - STRING Type
Waveform Type
Fc9-comp-macro.png ESERet
Returns the value in the Standard Event Status Enable Register in <nr1> numeric format. The syntax of the response is <nr1><rmt>.
Fc9-comp-macro.png SLVRST
Sets the SLAVE generator ready to be synchronised
Fc9-comp-macro.png SQRSYMM
Sets the square waveform symmetry to <nrf> %. (Lower limit: 20 - Upper limit: 80)
[[File:]] - Symmetry
Sets the square waveform symmetry in percent (20 - 80).
Fc9-comp-macro.png OUTPUT
Sets the output to; 0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT.
Fc9-u8-icon.png - BYTE SetOutput
Set the output. (0 = ON, 1 = OFF, 2 = NORMAL, 3 = INVERT).
Fc9-comp-macro.png MODPWMDEVWDT
Sets the PWM waveform deviation to <nrf> sec.
[[File:]] - Sec
Fc9-comp-macro.png SWPMODE
Sets the sweep mode to <CONT> or <TRIG>. 0 = CONT, 1 = TRIG.
[[File:]] - Mode
Set the sweep mode (0 = CONT, 1 = TRIG).
Fc9-comp-macro.png MODFSKRATE
Sets FSK rate to <nrf> Hz. (Lower limit: 2mHz - Upper limit: 100kHz).
[[File:]] - Rate
Sets FSK rate in Hertz(Hz) (2mHz - 100kHz).
Fc9-comp-macro.png BST
Sets the burst mode to; 0 = <OFF>, 1 = <NCYC>, 2= <GATED>, 3 = <INFINITE>.
Fc9-u8-icon.png - BYTE MODE
Sets the burst mode (0 = OFF, 1 = NCYC, 2 = GATED, 3 = INFINITE).
Fc9-comp-macro.png SYNCTYPE
Sets the sync type to; 0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER.
Fc9-u8-icon.png - BYTE Type
Set the sync type (0 = AUTO, 1 = CARRIER, 2 = MODULATION, 3 = SWEEP, 4 = BURST, 5 = TRIGGER).
Fc9-comp-macro.png MODPWMSHAPE
Sets PWM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets PWM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png LOLVL
Sets the amplitude-low-level to <nrf> Volts. (Lower limit: 5.000 V - Upper limit: -0.010 V).
[[File:]] - LowLevel
Sets the amplitude-low-level in Volts(V) (-5.000 V - -0.010 V).
Fc9-comp-macro.png SAV
Saves the complete instrument setup to the setup-file named <nrf>
Fc9-u8-icon.png - BYTE StoreLocation
Memory location of register (0-9)
Fc9-comp-macro.png TRG
This command is the same as pressing the TRIGGER key.
Fc9-comp-macro.png ARBDCOFFS
Sets the arbritary dc waveform offset to <nrf> volts.
[[File:]] - OffsetVoltage
Set the offset voltage
Fc9-comp-macro.png SWPTRGPOL
Sets the sweep trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the sweep trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png PULSRISE
[[File:]] - Rise
Sets the pulse waveform positive edge in micro seconds (5ns - 99.9ns).
Fc9-comp-macro.png MODAMSHAPE
Sets AM waveform shape to: 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets AM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Fc9-comp-macro.png CLKSRC
Sets the clock source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets the clock source (0 = INT, 1 = EXT).
Fc9-comp-macro.png ARB1DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1.
Sound one beep.
Fc9-comp-macro.png SWPCNTFREQ
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz).
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz).
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF.
[[File:]] - Sweep
Enable or disable the sweep (0 = ON, 1 = OFF).
Fc9-comp-macro.png BSTTRGSRC
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN.
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN).
Fc9-comp-macro.png MODPWMFREQ
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ARB2Ret
Fc9-comp-macro.png RST
Resets the instrument parameters to their default values.
Fc9-comp-macro.png RMPSYMM
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100)
Sets the ramp waveform symmetry in percent (0 - 100).
Fc9-comp-macro.png BSTCOUNT
Sets the burst count to <nrf> cycles, maximum 1048575 cycles.
[[File:]] - Count
Sets the burst count in cycles (1 - 1048575).
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF.
[[File:]] - Marker
Enable or disable the sweep marker (0 = ON, 1 = OFF).
Fc9-comp-macro.png PULSFREQ
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz).
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz).
Fc9-comp-macro.png MODFMDEV
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz).
[[File:]] - Deviation
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz).
Fc9-comp-macro.png RCL
Recalls the instrument setup contained in store <nrf>.
Memory location (0-9)
Fc9-comp-macro.png ESESet
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255)
Fc9-u8-icon.png - BYTE Value
Enable the register to this value. (0 - 255)
Fc9-comp-macro.png LOCAL
Returns the instrument to local opertion and unlocks the keyboard.
Fc9-comp-macro.png SWPSPNFREQ
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz).
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz).
Fc9-comp-macro.png CALSTEP
Step to the next calibration point.
Fc9-comp-macro.png OPC
Sets the Operation Complete bit (bit 0) in the Standard Event Status Register. This will happen immediately the command is executed because of the sequential nature of all operations.
Fc9-comp-macro.png SRERet
Returns the value of the Service Request Enable Register in <nr1> numeric format.
Fc9-comp-macro.png MODPMFREQ
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Fc9-comp-macro.png ARBRESIZE
Changes the size of arbritary waveform <cpd> to <nrf>.
[[File:]] - Size
Size of waveform
Fc9-string-icon.png - STRING Waveform
Arbritary Waveform
Fc9-comp-macro.png LRN
Intall data from a previous *LRN? command.
Fc9-comp-macro.png MODPMSHAPE
Sets PM waveform shape to; 0 = SINE, 1 = SQUARE, 2 = RAMPUP, 3 = RAMPDN, 4 = TRIANG, 5 = NOISE, 6 = DC, 7 = SINC, 8 = EXPRISE, 9 = LOGRISE, 10 = ARB1, 11 = ARB2, 12 = ARB3, 13= ARB4.
Sets PM waveform shape (1 = SINE, 2 = SQUARE, 3 = RAMPUP, 4 = RAMPDN, 5 = TRIANG, 6 = NOISE, 7 = DC, 8 = SINC, 9 = EXPRISE, 10 = LOGRISE, 11 = ARB1, 12 = ARB2, 13 = ARB3, 14= ARB4).
Loads the binary-data to an existing arbitrary waveform memory location ARB4.
Fc9-u8-icon.png - BYTE Waveform
Fc9-comp-macro.png CLKSRRet
Returns the clock source <INT> or <EXT>.
[[File:]] - Return
Fc9-comp-macro.png MODPMDEV
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°).
[[File:]] - Degrees
Sets PM waveform deviation in degrees (-360 - 360).
Fc9-comp-macro.png MSTLOCK
Sends signal to SLAVE generator to get synchronised
Fc9-comp-macro.png HILVL
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V).
[[File:]] - HighLevel
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V).
Loads the binary-data to an existing arbitrary waveform memory location ARB3.
Fc9-u16-icon.png - UINT Waveform
Sets the waveform type. 0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB
Fc9-u8-icon.png - BYTE WaveType
0 = SINE, 1 = SQUARE, 2 = RAMP, 3 = TRIANG, 4 = PULSE, 5 = NOISE, 6 = ARB.
Fc9-comp-macro.png CALADJ
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100).
[[File:]] - Calibrate
Adjust the selected calibration value (-100 - 100).
Fc9-comp-macro.png STBRet
Returns the value of the Status Byte Register in <nr1> numeric format.
Loads the binary-data to an existing arbitrary waveform memory location ARB2.
Fc9-comp-macro.png EERRet
Query and clear execution error number register.
Fc9-comp-macro.png MODFMSRC
Sets FM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets FM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODAMFREQ
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz).
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz).
Sets the Standard Event Status Enable Register to the value of <nrf>.
Value of register 0-255
Loads the binary-data to an existing arbitrary waveform memory location ARB1.
16 Bit binary number for arbitrary waveform.
Fc9-comp-macro.png ARB4DEFRet
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4.
Fc9-comp-macro.png CLS
Clears status byte register of the interface.
Fc9-comp-macro.png MSTRELOCK
Resynchronises the two generators in MASTER-SLAVE mode.
Fc9-comp-macro.png NOISLVL
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%)
Fc9-u8-icon.png - BYTE Percent
Sets the output noise level in percent. (0 - 50)
Fc9-comp-macro.png LOCKMODE
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP.
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP).
Fc9-comp-macro.png ADDRESSRet
Returns the instruments address
[[File:]] - Return
Fc9-comp-macro.png MODPMSRC
Sets PM waveform source to; 0 INT, 1 = EXT.
[[File:]] - Source
Sets PM waveform source (0 = INT, 1 = EXT).
Fc9-comp-macro.png MODPWMSRC
Sets PWM waveform source to; 0 = INT, 1 = EXT.
[[File:]] - Source
Sets PWM waveform source (0 = INT, 1 = EXT).
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM.
Fc9-u8-icon.png - BYTE Modulation
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM).
Fc9-comp-macro.png ISTRet
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true.
[[File:]] - Return
Fc9-comp-macro.png LRNRet
Returns the complete setup of the instrument as a binary data block
[[File:]] - Return
Fc9-comp-macro.png OPCRet
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential.
[[File:]] - Return
Fc9-comp-macro.png SWPTYPE
Sets the sweep type to; 0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP.
Set the sweep type (0 = LINUP, 1 = LINDN, 2 = LINUPDN, 3 = LINDNUP, 4 = LOGUP, 5 = LOGDN, 6 = LOGUPDN, 7 = LOGDNUP).
Fc9-comp-macro.png PULSRANGE
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3.
Fc9-u8-icon.png - BYTE Range
Sets the pulse rise and fall range. (1, 2 or 3)
Fc9-comp-macro.png TSTRet
The generator has no self test capability and the response is always 0 <rmt>.
[[File:]] - Return
Fc9-comp-macro.png BSTTRGPOL
Sets the burst trigger slope to; 0 = POS, 1 = NEG.
[[File:]] - Slope
Set the burst trigger slope (0 = POS, 1 = NEG).
Fc9-comp-macro.png ARB3Ret
Fc9-comp-macro.png BSTPHASE
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360)
[[File:]] - Degrees
Sets the burst phase in degrees (-360 - 360)
Fc9-comp-macro.png IDNRet
Returns the instrument identification. The IDN is saved to the variable passed from the function 'ReturnIDN'. The return parameter is TRUE when the IDN is successfully returned.
Fc9-string-icon.png - STRING ReturnIDN
Fc9-comp-macro.png SWPTRGPER
Sets the sweep trigger period to <nrf> seconds
[[File:]] - Seconds
Set the sweep trigger period in seconds.
Fc9-comp-macro.png PULSDLY
Sets the waveform delay to <nrf> sec
[[File:]] - Sec
Fc9-type-11-icon.png Title
Fc9-type-12-icon.png Vertical Alignment
Fc9-type-7-icon.png Show Comms Indicators
Fc9-type-16-icon.png Input Icon
Fc9-type-16-icon.png Output Icon
Fc9-conn-icon.png Simulations
