Component: WLAN (ESP 12S) (Comms: Networking)
Author | Matrix Ltd. |
Version | 2.1 |
Category | Comms: Networking |
WLAN component
Wireless LAN component designed to work with the ESP-12S module. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Also available in the form of the BL0136 WIFI E-block.
DisconnectFromSSID |
Disconnects from the current SSID. Returns 1 if the command was accepted and returned an "OK" | |
Return |
GetFirmwareVersion |
Collects the firmware version from the ESP8266 module and returns it as a string. | |
Return |
CheckForPageRequests |
To be called periodically. Returns non-zero if a request has been processed | |
Return |
ClientSendRequest |
Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser. | |
Request |
e.g. "GET / HTTP/1.0\r\n\r\n" | |
Return |
ReadSSIDFromScan |
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
Index |
SSID Index | |
Return |
SetOutValue |
Set the value of an outbound substitution string | |
index |
Range 0-4 | |
value |
Return |
EndServerConnection |
Disconnects from the current active TCP/IP pipe. | |
Return |
Send_Embedded_HTML_Page4 |
Return |
Send_Embedded_HTML_Page3 |
Return |
Send_Embedded_HTML_Page2 |
Return |
Send_Embedded_HTML_Page1 |
Return |
GetByteWithTimeout |
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available. | |
Return |
GetInValue |
Returns the string value of a Request parameter | |
index |
Index of the request paramter, starting at zero Range 0-2 | |
Return |
ClientSendArray |
Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser. | |
Data |
NumBytes |
Return |
Initialise |
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module | |
Return |
CheckTCPServerIP |
Collects the local IP address of the active TCP server. | |
Return |
CLKSRC |
Sets the clock source to; 0 = INT, 1 = EXT. | |
[[File:]] - | Source |
Sets the clock source (0 = INT, 1 = EXT). | |
Return |
ARB1DEFRet |
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1. | |
Return |
BEEP |
Sound one beep. | |
Return |
SWPCNTFREQ |
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
[[File:]] - | Frequency |
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz). | |
Return |
SWP |
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
[[File:]] - | Sweep |
Enable or disable the sweep (0 = ON, 1 = OFF). | |
Return |
BSTTRGSRC |
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN. | |
Source |
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN). | |
Return |
MODPWMFREQ |
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ARB2Ret |
Returns the binary-data from an existing abbitrary wavefrom memory location. | |
Return |
RST |
Resets the instrument parameters to their default values. | |
Return |
RMPSYMM |
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100) | |
[[File:]] - | Symmetry |
Sets the ramp waveform symmetry in percent (0 - 100). | |
Return |
BSTCOUNT |
Sets the burst count to <nrf> cycles, maximum 1048575 cycles. | |
[[File:]] - | Count |
Sets the burst count in cycles (1 - 1048575). | |
Return |
SWPMKR |
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
[[File:]] - | Marker |
Enable or disable the sweep marker (0 = ON, 1 = OFF). | |
Return |
PULSFREQ |
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz). | |
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz). | |
Return |
MODFMDEV |
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz). | |
[[File:]] - | Deviation |
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz). | |
Return |
RCL |
Recalls the instrument setup contained in store <nrf>. | |
StoreLocation |
Memory location (0-9) | |
Return |
ESESet |
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255) | |
Value |
Enable the register to this value. (0 - 255) | |
Return |
LOCAL |
Returns the instrument to local opertion and unlocks the keyboard. | |
Return |
SWPSPNFREQ |
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz). | |
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz). | |
Return |
CALSTEP |
Step to the next calibration point. | |
Return |
SRERet |
Returns the value of the Service Request Enable Register in <nr1> numeric format. | |
Return |
MODPMFREQ |
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ARBRESIZE |
Changes the size of arbritary waveform <cpd> to <nrf>. | |
[[File:]] - | Size |
Size of waveform | |
Waveform |
Arbritary Waveform | |
Return |
LRN |
Intall data from a previous *LRN? command. | |
Return |
ARB4 |
Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
Waveform |
Return |
CLKSRRet |
Returns the clock source <INT> or <EXT>. | |
[[File:]] - | Return |
MODPMDEV |
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
[[File:]] - | Degrees |
Sets PM waveform deviation in degrees (-360 - 360). | |
Return |
MSTLOCK |
Sends signal to SLAVE generator to get synchronised | |
Return |
HILVL |
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
[[File:]] - | HighLevel |
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
Return |
ARB3 |
Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
Waveform |
Return |
CALADJ |
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
[[File:]] - | Calibrate |
Adjust the selected calibration value (-100 - 100). | |
Return |
STBRet |
Returns the value of the Status Byte Register in <nr1> numeric format. | |
Return |
ARB2 |
Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
Waveform |
Return |
EERRet |
Query and clear execution error number register. | |
Return |
MODFMSRC |
Sets FM waveform source to; 0 INT, 1 = EXT. | |
Sets FM waveform source (0 = INT, 1 = EXT). | |
Return |
MODAMFREQ |
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ESE |
Sets the Standard Event Status Enable Register to the value of <nrf>. | |
Value |
Value of register 0-255 | |
Return |
ARB1 |
Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
Waveform |
16 Bit binary number for arbitrary waveform. | |
Return |
ARB4DEFRet |
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
Return |
CLS |
Clears status byte register of the interface. | |
Return |
MSTRELOCK |
Resynchronises the two generators in MASTER-SLAVE mode. | |
Return |
NOISLVL |
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
Percent |
Sets the output noise level in percent. (0 - 50) | |
Return |
LOCKMODE |
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
Mode |
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
Return |
ADDRESSRet |
Returns the instruments address | |
MODPMSRC |
Sets PM waveform source to; 0 INT, 1 = EXT. | |
Sets PM waveform source (0 = INT, 1 = EXT). | |
Return |
MODPWMSRC |
Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
Sets PWM waveform source (0 = INT, 1 = EXT). | |
Return |
MOD |
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
Modulation |
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
Return |
ISTRet |
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
LRNRet |
Returns the complete setup of the instrument as a binary data block | |
OPCRet |
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
PULSRANGE |
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
Range |
Sets the pulse rise and fall range. (1, 2 or 3) | |
Return |
TSTRet |
The generator has no self test capability and the response is always 0 <rmt>. | |
BSTTRGPOL |
Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
[[File:]] - | Slope |
Set the burst trigger slope (0 = POS, 1 = NEG). | |
Return |
ARB3Ret |
Return |
BSTPHASE |
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
Sets the burst phase in degrees (-360 - 360) | |
Return |
SWPTRGPER |
Sets the sweep trigger period to <nrf> seconds | |
[[File:]] - | Seconds |
Set the sweep trigger period in seconds. | |
Return |
PULSDLY |
Sets the waveform delay to <nrf> sec | |
[[File:]] - | Sec |
Return |
Initialise |
Opens the COM port ready for communications. | |
Return |
