Component: Webserver (GENERIC Flash / File) (Comms: Networking)
Author | Matrix Ltd. |
Version | 1.5 |
Category | Comms: Networking |
Webserver (GENERIC - Flash / File) component
Webserver component designed to work with Network Comms abstraction layer. Provides a very simple interface to allow webpages to be hosted from hardware or simulation. Webpages can be embedded into ROM or can be pulled directly from a local file or a SD card via the File component. The File mode allows for images and other media to be served to the web client.
Webserver Embedded Files
A simple example demonstrating how to host a website with fixed HTTP content including dynamic sections that can be passed in and out of Flowcode SCADA.
For example a dynamic section could be used to display a variable value on a webpage such as a temperature or used to control Flowcode e.g. turn on an output.
Webserver Dynamic Files
Flowcode Embedded
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of an embedded system using an SD card and an ESP8266 module.
Flowcode App Developer
A simple example demonstrating how to host a website with dynamic content based on external files including dynamic sections that can be passed in and out of Flowcode App Developer.
SetOutValue |
Set the value of an outbound substitution string | |
Index |
Incoming string Index Range: 0 to Outgoing Count - 1 | |
Value |
Return |
GetInValue |
Returns the string value of a Request parameter | |
Index |
Incoming string Index Range: 0 to Incoming Count - 1 | |
Return |
Initialise |
Resets and initialises the Web Server component. | |
Return |
ClientSendRequest |
Sends out a string with the required AT+CIPSEND=Length$(Request) initialiser. | |
Request |
e.g. "GET / HTTP/1.0\r\n\r\n" | |
Return |
ReadSSIDFromScan |
Collects one of the SSID name strings from the last SSID Scan. The ScanForSSID macro must be called first. | |
Index |
SSID Index | |
Return |
SetOutValue |
index |
Range 0-4 | |
value |
Return |
EndServerConnection |
Disconnects from the current active TCP/IP pipe. | |
Return |
Send_Embedded_HTML_Page4 |
Return |
Send_Embedded_HTML_Page3 |
Return |
Send_Embedded_HTML_Page2 |
Return |
Send_Embedded_HTML_Page1 |
Return |
GetByteWithTimeout |
Attempts to receive a byte from the circular buffer. If nothing is available then waits up to 200 ms for data to become available. | |
Return |
GetInValue |
index |
Index of the request paramter, starting at zero Range 0-2 | |
Return |
ClientSendArray |
Sends out an array of data bytes with the required AT+CIPSEND=Length$(Request) initialiser. | |
Data |
NumBytes |
Return |
Initialise |
Initialise the device with the property data. Returns 1 if "ready" message successfully received Returns 0 if no reply from module | |
Return |
CheckTCPServerIP |
Collects the local IP address of the active TCP server. | |
Return |
CLKSRC |
Sets the clock source to; 0 = INT, 1 = EXT. | |
[[File:]] - | Source |
Sets the clock source (0 = INT, 1 = EXT). | |
Return |
ARB1DEFRet |
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB1. | |
Return |
BEEP |
Sound one beep. | |
Return |
SWPCNTFREQ |
Sets the sweep centre frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50MHz). | |
[[File:]] - | Frequency |
Sets the sweep centre frequency in Hertz(Hz) (1uHz - 50MHz). | |
Return |
SWP |
Sets the sweep to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
[[File:]] - | Sweep |
Enable or disable the sweep (0 = ON, 1 = OFF). | |
Return |
BSTTRGSRC |
Sets the burst trigger source to; 0 = INT, 1 = EXT, 2 = MAN. | |
Source |
Set the burst trigger source (0 = INT, 1 = EXT, 2 = MAN). | |
Return |
MODPWMFREQ |
Sets PWM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets PWM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ARB2Ret |
Returns the binary-data from an existing abbitrary wavefrom memory location. | |
Return |
RST |
Resets the instrument parameters to their default values. | |
Return |
RMPSYMM |
Sets the ramp waveform symmetry to <nrf> %. (Lower limit: 0 - Upper limit: 100) | |
[[File:]] - | Symmetry |
Sets the ramp waveform symmetry in percent (0 - 100). | |
Return |
BSTCOUNT |
Sets the burst count to <nrf> cycles, maximum 1048575 cycles. | |
[[File:]] - | Count |
Sets the burst count in cycles (1 - 1048575). | |
Return |
SWPMKR |
Sets the sweep marker to <ON> or <OFF>. 0 = ON, 1 = OFF. | |
[[File:]] - | Marker |
Enable or disable the sweep marker (0 = ON, 1 = OFF). | |
Return |
PULSFREQ |
Sets the pulse waveform frequency to <nrf> Hz (Lower limit: 1uHz - Upper limit: 50MHz). | |
Sets the pulse waveform frequency in Hertz(Hz) (1uHz - 50MHz). | |
Return |
MODFMDEV |
Sets FM waveform deviation to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 25MHz). | |
[[File:]] - | Deviation |
Sets FM waveform deviation in Hertz(Hz) (1uHz - 25MHz). | |
Return |
RCL |
Recalls the instrument setup contained in store <nrf>. | |
StoreLocation |
Memory location (0-9) | |
Return |
ESESet |
Sets the standard event status enable register to the value of <nrf>. (Lower limit: 0 - Upper limit: 255) | |
Value |
Enable the register to this value. (0 - 255) | |
Return |
LOCAL |
Returns the instrument to local opertion and unlocks the keyboard. | |
Return |
SWPSPNFREQ |
Sets the sweep frequency span to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 50.25kHz). | |
Set the sweep frequency span in Hertz(Hz) (1uHz - 50.25kHz). | |
Return |
CALSTEP |
Step to the next calibration point. | |
Return |
SRERet |
Returns the value of the Service Request Enable Register in <nr1> numeric format. | |
Return |
MODPMFREQ |
Sets PM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets FM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ARBRESIZE |
Changes the size of arbritary waveform <cpd> to <nrf>. | |
[[File:]] - | Size |
Size of waveform | |
Waveform |
Arbritary Waveform | |
Return |
LRN |
Intall data from a previous *LRN? command. | |
Return |
ARB4 |
Loads the binary-data to an existing arbitrary waveform memory location ARB4. | |
Waveform |
Return |
CLKSRRet |
Returns the clock source <INT> or <EXT>. | |
[[File:]] - | Return |
MODPMDEV |
Sets PM waveform deviation to <nrf> degrees. (Lower limit: -360° - Upper limit: 360°). | |
[[File:]] - | Degrees |
Sets PM waveform deviation in degrees (-360 - 360). | |
Return |
MSTLOCK |
Sends signal to SLAVE generator to get synchronised | |
Return |
HILVL |
Sets the amplitude-high-level to <nrf> Volts. (Lower limit: -0.490 V - Upper limit: 5.000 V). | |
[[File:]] - | HighLevel |
Sets the amplitude-high-level in Volts(V) (-0.490 V - 5.000 V). | |
Return |
ARB3 |
Loads the binary-data to an existing arbitrary waveform memory location ARB3. | |
Waveform |
Return |
CALADJ |
Adjust the selected calibration value by <nrf> (Lower limit: -100 - Upper limit: 100). | |
[[File:]] - | Calibrate |
Adjust the selected calibration value (-100 - 100). | |
Return |
STBRet |
Returns the value of the Status Byte Register in <nr1> numeric format. | |
Return |
ARB2 |
Loads the binary-data to an existing arbitrary waveform memory location ARB2. | |
Waveform |
Return |
EERRet |
Query and clear execution error number register. | |
Return |
MODFMSRC |
Sets FM waveform source to; 0 INT, 1 = EXT. | |
Sets FM waveform source (0 = INT, 1 = EXT). | |
Return |
MODAMFREQ |
Sets AM waveform frequency to <nrf> Hz. (Lower limit: 1uHz - Upper limit: 20kHz). | |
Sets AM waveform frequency in Hertz(Hz) (1uHz - 20kHz). | |
Return |
ESE |
Sets the Standard Event Status Enable Register to the value of <nrf>. | |
Value |
Value of register 0-255 | |
Return |
ARB1 |
Loads the binary-data to an existing arbitrary waveform memory location ARB1. | |
Waveform |
16 Bit binary number for arbitrary waveform. | |
Return |
ARB4DEFRet |
Returns user specified waveform name, waveform pint interpolation state and waveform length of ARB4. | |
Return |
CLS |
Clears status byte register of the interface. | |
Return |
MSTRELOCK |
Resynchronises the two generators in MASTER-SLAVE mode. | |
Return |
NOISLVL |
Sets the output noise level to <nr1> %. (Lower limit: 0% - Upper limit: 50%) | |
Percent |
Sets the output noise level in percent. (0 - 50) | |
Return |
LOCKMODE |
Sets the synchronising mode to; 0 = MASTER, 1 = SLAVE, 2 = INDEP. | |
Mode |
Sets the synchronising mode (0 = MASTER, 1 = SLAVE, 2 = INDEP). | |
Return |
ADDRESSRet |
Returns the instruments address | |
MODPMSRC |
Sets PM waveform source to; 0 INT, 1 = EXT. | |
Sets PM waveform source (0 = INT, 1 = EXT). | |
Return |
MODPWMSRC |
Sets PWM waveform source to; 0 = INT, 1 = EXT. | |
Sets PWM waveform source (0 = INT, 1 = EXT). | |
Return |
MOD |
Sets modulation to; 0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM. | |
Modulation |
Sets modulation (0 = OFF, 1 = AM, 2 = FM, 3 = PM, 4 = FSK, 5 = PWM). | |
Return |
ISTRet |
Returns IST local message as defined by IEEE Std. 488.2. The syntax of the response is 0<rmt>, if the local message is false, or 1<rmt>, if the local message is true. | |
LRNRet |
Returns the complete setup of the instrument as a binary data block | |
OPCRet |
Query Operation Complete status. The response is always 1<rmt> and will be available immediately the command is executed because all commands are sequential. | |
PULSRANGE |
Sets PWM waveform source to <1>, <2> or <3>; 1 = 1, 2 = 2, 3 = 3. | |
Range |
Sets the pulse rise and fall range. (1, 2 or 3) | |
Return |
TSTRet |
The generator has no self test capability and the response is always 0 <rmt>. | |
BSTTRGPOL |
Sets the burst trigger slope to; 0 = POS, 1 = NEG. | |
[[File:]] - | Slope |
Set the burst trigger slope (0 = POS, 1 = NEG). | |
Return |
ARB3Ret |
Return |
BSTPHASE |
Sets the burst phase to <nrf> degrees. (Lower limit: -360 - Upper limit: 360) | |
Sets the burst phase in degrees (-360 - 360) | |
Return |
SWPTRGPER |
Sets the sweep trigger period to <nrf> seconds | |
[[File:]] - | Seconds |
Set the sweep trigger period in seconds. | |
Return |
PULSDLY |
Sets the waveform delay to <nrf> sec | |
[[File:]] - | Sec |
Return |
Initialise |
Opens the COM port ready for communications. | |
Return |
