Component: GLCD Graph Creator XY (Graphical Library)
Revision as of 21:01, 16 November 2021 by Wiki bot (talk | contribs)
Version 1.2
Category Graphical Library
GLCD Graph Creator XY component
A component to simplify the process of drawing XY graphs and charts using a graphical LCD.
The graph creator XY component must be linked to the graphical LCD using the gLCD Object property.
The X Coord, Y Coord, Width and Height component properties set the size and position of the graph on the gLCD.
In the attached example the ADC component sets the input to the graph. Every 50ms a sample is taken and added to the graph.
FC6 Icon.png Graph Creator Demo
Any size of graph can be created. For efficiency it is best to try and stick to the following rules.
  • The width should be equal to or a multiple of the X input range - Min Value 0 to Max Value 255 = input range of 256
  • The height should be equal to or a multiple of the Y input range - Min Value 0 to Max Value 255 = input range of 256
  • If Show Border is enabled then Width and Height should be as above plus 2 to account for the border pixels
Fc9-comp-macro.png ExportToCSV
Exports the data in the graph to a CSV file.
[[File:]] - Erase
0=Append existing data, 1=Reset file data
Fc9-comp-macro.png AddPoint
Adds a new data point to the graph.
[[File:]] - X
X Data Value to plot
[[File:]] - Y
Y Data Value to plot
Fc9-u8-icon.png - BYTE Index
Plot Index: Range 0-7
Fc9-comp-macro.png Initialise
Initialises the graph object on the GLCD to the specified dimensions.
Fc9-u8-icon.png - BYTE Font
Fc9-comp-macro.png Print
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u8-icon.png - BYTE Pixel_Colour
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-u8-icon.png - BYTE Solid
Fc9-u8-icon.png - BYTE Red
Fc9-u8-icon.png - BYTE Green
Fc9-u8-icon.png - BYTE Blue
Fc9-type-17-icon.png gLCD Object
Graphical LCD Object to draw the graph on
Fc9-type-7-icon.png ColourDisplay
Automatically detects if the graphical LCD object is colour or monochrome
Fc9-type-21-icon.png X Coord
X coordinate for the top left of the graph container rectangle
Fc9-type-21-icon.png Y Coord
Y coordinate for the top left of the graph container rectangle
Fc9-type-21-icon.png Width
Horizontal size of the graph in pixels
Fc9-type-21-icon.png Height
Vertical size of the graph in pixels
Fc9-type-16-icon.png Number Of Plots
Determines the number of plots that can be displayed simultaneously on the graph. Monochrome displays can only support a single plot.
Fc9-type-21-icon.png Number Of Points
Number of data points the graph can store, multiplied by the number of plots.
Fc9-type-16-icon.png Graph Style
Controls the graph draw style. Point - Draws a single point Line - Draws a line from the last point to the new point
Fc9-type-14-icon.png Min X Value
Value to represent the bottom Y axis on the graph
Fc9-type-14-icon.png Max X Value
Value to represent the top Y axis on the graph
Fc9-type-14-icon.png Min Y Value
Fc9-type-14-icon.png Max Y Value
Fc9-type-7-icon.png Show Border
Decides if a border for the graph is generated
Fc9-type-16-icon.png Show Grid
Decides if a X or Y grid is shown for the graph
Fc9-type-21-icon.png X Subdivisions
Number of horizontal divisions to draw
Fc9-type-21-icon.png Y Subdivisions
Number of vertical divisions to draw
Determines the graph background colour.
Fc9-type-1-icon.png Grid Colour
Determines the graph grid colour.
Fc9-type-1-icon.png Plot 0 Colour
Determines the graph plot colour.
Fc9-conn-icon.png Simulations
