Component: LCD (Generic, Configurable) ()
Revision as of 21:01, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.1 |- | width="20%" style="color:gray...")
Version 1.1
Category
LCD (Generic, Configurable) component
LCD based on the standard hitachi alphanumeric display unit.
Fc9-comp-macro.png PrintAscii
Fc9-u8-icon.png - BYTE character
Holds an ascii value.
Based on v5 macro, will allow you to print a number. This is limited to a signed-INT, -32768 to 32767
[[File:]] - Number
Fc9-comp-macro.png RAMWrite
Fc9-u8-icon.png - BYTE Index
Values 0 to 7
Fc9-u8-icon.png - BYTE d0
Fc9-u8-icon.png - BYTE d1
Fc9-u8-icon.png - BYTE d2
Fc9-u8-icon.png - BYTE d3
Fc9-u8-icon.png - BYTE d4
Fc9-u8-icon.png - BYTE d5
Fc9-u8-icon.png - BYTE d6
Fc9-u8-icon.png - BYTE d7
Fc9-comp-macro.png ClearLine
Fc9-u8-icon.png - BYTE Line
The line to clear, zero being the first (top) line of the display
Fc9-comp-macro.png Cursor
Fc9-u8-icon.png - BYTE x
Set the cursor position in the X plane, 0 is the left most cell
Fc9-u8-icon.png - BYTE y
Set the cursor position in the Y plane, 0 is the top most cell
Fc9-comp-macro.png Command
Fc9-u8-icon.png - BYTE instruction
Send a defined command to the LCD Screen. See datasheet for supported commands.
Fc9-comp-macro.png PrintFormattedNumber
Fc9-u32-icon.png - ULONG Number
[[File:]] - Format
0=Signed, 1=Unsigned
Fc9-comp-macro.png ScrollDisplay
Fc9-u8-icon.png - BYTE Position
Holds the number of positions to shift the display
Fc9-u8-icon.png - BYTE Direction
0 = left, 1 = right
Fc9-comp-macro.png RawSend
Sends data to the LCD display
Fc9-u8-icon.png - BYTE data
The data byte to send to the LCD
[[File:]] - type
A boolean to indicate command type: true to write data, false to write a command
Fc9-comp-macro.png RemapCharacter
Assigns a remap character allowing the PrintString function to automatically swap between pre-defined characters. The characters can be custom (in the range 0-9) or can point to an existing character in the LCD character map.
Fc9-u8-icon.png - BYTE RemapIdx
Remap Index, Range: 0 to (Remap Characters - 1)
Fc9-u8-icon.png - BYTE SearchCharacter
Character to look for a replace
Fc9-u8-icon.png - BYTE ReplacementCharacter
New character value to use in place of the search character.
Fc9-comp-macro.png Start
Startup routine required by the hardware device. Automatically clears the display after initialising.
Fc9-u8-icon.png - BYTE PixelColour
0=White, 1=Black
Fc9-comp-macro.png DrawCircle
Fc9-u16-icon.png - UINT X
Fc9-u16-icon.png - UINT Y
Fc9-u8-icon.png - BYTE Solid
0=White, 1=Black
Fc9-u16-icon.png - UINT X1
Fc9-u16-icon.png - UINT Y1
Fc9-u16-icon.png - UINT X2
Fc9-u16-icon.png - UINT Y2
Fc9-comp-macro.png Initialise
Fc9-comp-macro.png InvertDisplay
Fc9-type-16-icon.png Rows
Number of lines of characters the LCD can display.
Fc9-type-16-icon.png Columns
Number of characters the LCD can display on a single line.
Fc9-type-21-icon.png Remap Characters
Used to allow characters to be replaced with alternate characters. Custom characters or characters from the LCD memory map can be used as replacements. Each replacement consumes two bytes of RAM memory and is applied automatically when printing strings.
Fc9-type-21-icon.png Delay Timings
Delay in microseconds used in the display send function. Most displays will work with the default value of 100us. Some displays may need a slightly longer delay, 166us is known to work well.
Simulation only background colour, the actual hardware will have a fixed colour
Fc9-type-1-icon.png Line Color
Simulation only line colour, the actual hardware will have a fixed colour
Fc9-type-1-icon.png Text Color
Simulation only text colour, the actual hardware will have a fixed colour
Fc9-type-3-icon.png Font
Font to use for simulation, the actual hardware will have a inbuilt fixed font.
Fc9-type-16-icon.png Interface mode
Choose between 4-bit mode, 8-bit mode and 8-bit mode using a port instead of individual pins to improve code efficiency.
Fc9-type-5-icon.png Data 0 (11 / 7)
Data pin 0 - Connects to Data 4 on the hardware in 4-bit mode or Data 0 in 8-bit mode
Fc9-type-5-icon.png Data 1 (12 / 8)
Data pin 1 - Connects to Data 5 on the hardware in 4-bit mode or Data 1 in 8-bit mode
Fc9-type-5-icon.png Data 2 (13 / 9)
Data pin 2 - Connects to Data 6 on the hardware in 4-bit mode or Data 2 in 8-bit mode
Fc9-type-5-icon.png Data 3 (14 / 10)
Data pin 3 - Connects to Data 7 on the hardware in 4-bit mode or Data 3 in 8-bit mode
Fc9-type-5-icon.png Register Select (4)
Register Select Pin - Informs the display if a command or data is about to be sent.
Fc9-type-5-icon.png Enable (6)
Enable pin - Used to synchronise data writes to the display
Fc9-type-7-icon.png Use Read/Write Pin
Set to "true" if the displays R/W pin is not hard wired. Set to "false" if the R/W pin is wired to ground.
Fc9-conn-icon.png Simulations
