Author
Matrix Ltd
Version
1.6
Category
Graphical Monochrome
GLCD (PDC8544) component
Graphical display component based on the PCD8544 monochrome graphical controller IC as used on the popular Nokia 5510 displays. Functions without the use of a read pin by hosting the 1K of graphical memory using the microcontroller's RAM memory.
ReadFontWidth
- BYTE
Font
- BYTE
Character
- BYTE
SetFontScaler
- BYTE
ScaleX
- BYTE
ScaleY
[[File:]] -
Number
- UINT
X
- UINT
Y
- BYTE
Font
- BYTE
Transparent
DrawLine
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
DrawEllipse
- UINT
X
- UINT
Y
- UINT
XRadius
- UINT
YRadius
- BYTE
Transparent
- BYTE
Solid
Plot
- UINT
X1
- UINT
Y1
SetDisplayOrientation
- BYTE
Orientation
BPlot
- UINT
X1
- UINT
Y1
ReadFontStat
- BYTE
Font
- BYTE
Index
0=SpaceWidth, 1=PixelHeight
- BYTE
Print
- STRING
Str
- UINT
X1
- UINT
Y1
- BYTE
Font
- BYTE
Transparent
ControlContrast
Allows the display bias and contrast to be configured to allow for various different display conditions.
- BYTE
Bias
Range: 0-7 / Default 4
- BYTE
Contrast
Range: 0-127 / Default 49
ClearDisplay
SetBackgroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawCircle
- UINT
X
- UINT
Y
- UINT
Radius
- BYTE
Transparent
- BYTE
Solid
SetForegroundColour
- BYTE
PixelColour
0=White, 1=Black
DrawRectangle
- UINT
X1
- UINT
Y1
- UINT
X2
- UINT
Y2
- BYTE
Transparent
- BYTE
Solid
Pixel Width
Pixel Height
Monochrome
Foreground Color
Background Color
Use Buffer
The display is only capable of writing to 8 pixels at once and there is no means to read back the pixel states. The internal RAM buffer is designed to allow you to do more with the display by keeping track of the pixel states. The internal RAM buffer when enabled will consume 504 bytes of RAM memory. For very basic printing of text with Y coordinates on 8-bit boundaries, 0, 8, 16, etc the buffer is not required as we never overlap the text. If the text was printed on say y coordinate of 4 and 12 then the text at coordinate 12 would corrupt the bottom of the text at coorinate 4.
Colour Bit Depth
Red Bit Depth
Green Bit Depth
Blue Bit Depth
Font Count
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Font
Character Spacing
Space Width
Display Method
Chip Enable (CE)
Chip select pin connection
Reg Select (DC)
Data (DIN)
Serial Clock (CLK)
Reset pin connection
Reset (RST)
Simulations
