Component: Coupling (Mechatronics)
Version | 1.0 |
Category | Mechatronics |
Coupling component
A simple component to couple together two rotating shafts. An essential component when working with motors, gearboxes, encoders and other rotational systems.
Rotate |
Simulation macro called behind the scenes by motor components when rotating. | |
[[File:]] - | Angle |
Return |
FT_SetRts |
This function sets the Request To Send (RTS) control signal. | |
[[File:]] - | Handle |
Handle of the device. | |
Return |
FT_Close |
Close an open device. | |
Return |
FT_ClrDtr |
This function clears the Data Terminal Ready (DTR) control signal. | |
Return |
FT_SetBreakOff |
Resets the BREAK condition for the device. | |
Return |
FT_SetDivisor |
This function sets the baud rate for the device. It is used to set non-standard baud rates. | |
Divisor |
Divisor. | |
Return |
FT_SetBaudRate |
This function sets the baud rate for the device. | |
BaudRate |
Baud rate. | |
Return |
FT_SetDtr |
This function sets the Data Terminal Ready (DTR) control signal. | |
Return |
ScanFor232 |
Scans for a FTDI D2XX device, returnes true if at least one device was found. | |
[[File:]] - | Return |
FT_ResetDevice |
This function sends a reset command to the device. | |
Return |
