Component: Maze Generator (HP458) (Scenarios)
Author | Matrix Ltd |
Version | 1.0 |
Category | Scenarios |
Maze Generator component
Creates a simulation only randomised maze out of standard micromouse maze walls and pillars. Compatible with the Formula Flowcode robot.
GenerateMaze |
Clears the current maze and generates a new maze over the top. Automatically called when the size of the maze is altered. | |
Return |
Forward |
Drives both motors of the formula flowcode forwards with the power specified. | |
Power |
Return |
ReadLineSensor |
Returns the digital value from the line sensor specified. | |
Sensor |
Return |
SpinRight |
Spins the formula flowcode on the spot in a clockwise direction as seen from above. | |
Power |
Return |
CheckIR |
Checks to see if a IR sensor is within the master threshold distance. | |
Sensor |
Return |
ReadIRSensor |
Reads the analogue value from the specified IR distance sensor. | |
Sensor |
Return |
SetMotors |
Sets the speed and direction of the Formula Flowcode motors. | |
[[File:]] - | Left_Power |
Valid Range = -255 to 255 | |
[[File:]] - | Right_Power |
Return |
Reverse |
Drives both motors of the formula flowcode backwards with the power specified. | |
Power |
Return |
WaitForSwitch |
Waits for the specified switch to be pressed. | |
Switch |
Return |
ReadLDR |
Reads the current audio signal level from the on-board light sensor. | |
[[File:]] - | Return |
WriteLEDs |
Allows control of all 8-LEDs on the front of the Formula Flowcode. | |
LED_Byte |
Return |
Initialise |
Starts up the formula flowcode PWM for motor control and performs the wait for button press | |
Return |
