Component: Servo Motor (Tower Pro 9g) ()
Revision as of 21:05, 16 November 2021 by Wiki bot (talk | contribs) (Created page with "{| style="width:50%" |- | width="20%" style="color:gray;" | Author | Matrix Ltd |- | width="20%" style="color:gray;" | Version | 1.1 |- | width="20%" style="color:gray...")
Version 1.1
Category
Servo Motor (Tower Pro 9g) component
Small size 9g servo motor suitable for control by the 'Servo Controller' component. Use the 'Link to...' property to attach other objects to the rotor for emulating mechanical systems. Send a virtual PWM signal to the servo by selecting it as a target of the 'Servo Controller' component.
Please note that the servo motor template and child components require the Servo Controller component to control them.
Controlling a servo with an analogue input
This example reads the value of the analogue potentiometer and uses this to set the position of the servo motor. FC6 Icon.png Servo Example 1 The Servo controller is linked to the standard servo component but this could be linked to any object on the panel.
Creating a multi-axis actuator using servo motors
This example links two servo motors together using panel primitive objects and groups. FC6 Icon.png Servo Example 2 The Servo controller can handle up to 8 motors and is used to control both of the standard servo components on the panel.
Fc9-comp-macro.png Forward
Drives both motors of the formula flowcode forwards with the power specified.
Fc9-u8-icon.png - BYTE Power
Fc9-comp-macro.png ReadLineSensor
Returns the digital value from the line sensor specified.
Fc9-u8-icon.png - BYTE Sensor
Fc9-comp-macro.png SpinRight
Spins the formula flowcode on the spot in a clockwise direction as seen from above.
Fc9-comp-macro.png CheckIR
Checks to see if a IR sensor is within the master threshold distance.
Fc9-comp-macro.png ReadIRSensor
Reads the analogue value from the specified IR distance sensor.
Fc9-comp-macro.png SetMotors
Sets the speed and direction of the Formula Flowcode motors.
[[File:]] - Left_Power
Valid Range = -255 to 255
[[File:]] - Right_Power
Fc9-comp-macro.png Reverse
Drives both motors of the formula flowcode backwards with the power specified.
Fc9-comp-macro.png WaitForSwitch
Waits for the specified switch to be pressed.
Fc9-u8-icon.png - BYTE Switch
Fc9-comp-macro.png ReadLDR
Reads the current audio signal level from the on-board light sensor.
[[File:]] - Return
Fc9-comp-macro.png WriteLEDs
Allows control of all 8-LEDs on the front of the Formula Flowcode.
Fc9-u8-icon.png - BYTE LED_Byte
Fc9-comp-macro.png Initialise
Starts up the formula flowcode PWM for motor control and performs the wait for button press
Fc9-type-17-icon.png Link To...
Select a panel object here to connect it 'mechanically' to the servo's actuator. The selected object will now be moved whenever the servo position changes. NB) To move multiple objects, first group the objects, and then select the group.
Fc9-type-7-icon.png Reverse Output
Some manufacturers motors may rotate in different ways to others. Changing this property allows you to flip the direction of the motor.
Fc9-type-16-icon.png Movement Type
Fc9-conn-icon.png Simulations
