Author
Matrix TSL
Version
1.5
Category
Advanced Shapes
Meter Square component
Square analogue panel meter. A simulation only component - the needle value is set solely by the 'SetValue' macro.
SetValue
Set the meter needle to a new position based on the current scaling properties.
[[File:]] -
Value
Needle position between min and max
TurnOff
De-activate the solenoid
DisableMotor
Turn off the motor. It will no longer respond to any other macros.
SetTrim
Allows the level of trim for each servo channel to be adjusted progmatically.
- BYTE
The channel to set the position for. First channel is zero.
- BYTE
Trim
Legacy: 0=0us, 1=+25us, 2=+50us, 3=+75us, 4=+100us, 5=-25us, 6=-50us, 7=-75us, 8=-100us or Smooth: 0-200
IsAutoMoving
Is the AutoMoveToPosition movement complete. Returns 1 if the servos are still moving. Returns 0 if all servo movement is complete.
- BYTE
SetAutoMoveSpeedInt
Sets the speed of the auto move to position macro. Default speed is shown in the Servo_Period_Multiplier property.
- UINT
Speed
1=Slowest (Default), 2= Double, 3=Triple, 4=Quadruple
IsServoAutoMoving
Is the AutoMoveToPosition movement complete for a specific servo output. Returns 1 if the servo is still moving. Returns 0 if the servo movement is complete.
- BYTE
Servo Motor Output Range: 0-7
- BYTE
AutoMoveToPosition
Automatically moves towards the new position at a fixed rate determined by the AutoMoveSpeed.
- BYTE
The channel to assign the new position. Range: 0-7
- BYTE
Position
Position to automatically move to. Range: 0-255
EnableServo
Enables a servo channel effectivly setting the position of the motor to the value in the local position variable.
- BYTE
SetAutoMoveSpeed
- BYTE
Speed
AutoMoveToPositionInt
Automatically moves towards the new 16-bit position at a fixed rate determined by the AutoMoveSpeed.
- BYTE
- UINT
Position
Position to automatically move to. Range: 0-65535
Sets up the servo motor interrupts
WriteLEDs
Allows control of all 8-LEDs on the front of the Formula Flowcode.
- BYTE
LED_Byte
Starts up the formula flowcode PWM for motor control and performs the wait for button press
Minimum
Minimum value to show on the meter.
Maximum
Maximum value to show on the meter.
BG Color
Color of the meter scale background.
Positive Color
Color of the scale gradations for positive values.
Negative Color
Color of the scale gradations for negative values.
Label Color
Color of the meter's title label.
Divisions
Number of large scale divisions..
Subdivisions
Number of sub-divisions in between each major division.
Show
Show or hide the scale markings.
Decimals
Number of decimal points to show on scale values.
Text Size %
Text height of the scale values.
Font
Font for the scale value numbers.
Show
Show or hide the scale number values.
Text
A title label to make the meter easier to identify.
Text Size %
Height of the label text.
Font
Font for printing the label.
Show
Show or hide the title label.
Simulations
