Component: DAC (MCP49x1) (Analog Output)
Version | 1.0 |
Category | Analog Output |
DAC component
Component to drive a digital to analogue converter (DAC) IC from Microchip via an SPI interface. Compatible with MCP4901 (8-Bit), MCP4911 (10-Bit) and MCP4921 (12-Bit) devices.
SetOutput |
Sets the output voltage of the DAC 8-Bit: Range 0-255 10-Bit: Range 0-1023 12-Bit: Range 0-4095 | |
DAC_Value |
The value to output to the DAC | |
Return |
Disable |
Disables the DAC output. | |
Return |
Enable |
Enables the DAC Output. | |
Channel |
0=DAC Channel 0 , 1=DAC Channel 1 | |
Return |
Initialise |
Configures the SPI peripheral ready for communications and initialises the internal variables. DAC needs to be enabled before any output voltage can be generated. | |
Return |
Initialise |
Return |
WriteLEDs |
Allows control of all 8-LEDs on the front of the Formula Flowcode. | |
LED_Byte |
Return |
Initialise |
Starts up the formula flowcode PWM for motor control and performs the wait for button press | |
Return |
