Author
Matrix
Version
1.2
Category
LED Multicolour RGB (5mm, PCB) component
A simulatable RGB LED in a standard 5mm through-hole PCB mount package. Three port pins each output a simple PWM signal - one for each of the primary colours. The colors can then be mixed in any proportions to allow the desired color to be produced.
Enable
Enables the RGB LED. This must be done before the LED can be lit or the color changed.
Tick
Call this macro at regular intervals to illuminate the LED with the chosen color. Turns each pin on and off to generate a simple PWM signal for each color - when done rapidly, this gives the illusion of the chosen color.
SetColor
Set the target color for the LED. Each of the Red, Blue and Green channels can be set to any value from 0 (off) to 255 (full brightness).
- BYTE
red
Red component of RGB LED local to this macro
- BYTE
green
Green component of RGB LED local to this macro
- BYTE
blue
Blue component of RGB LED local to this macro
WriteMicroseconds
Sets the PWM output of one of the PCA9685 pins based on the input microseconds, output is not precise
- BYTE
Output
One of the PWM output pins - Range: 0 to 15
- UINT
Microseconds
The number of Microseconds to turn the PWM output ON
SetPWM
- BYTE
Output
- UINT
On
At what point in the 4096-part cycle to turn the PWM output ON
- UINT
Off
At what point in the 4096-part cycle to turn the PWM output OFF
Sets up the I2C ready for communications to begin
WakeUp
Wakes the module from Sleep mode
SetPin
Sets pin without having to deal with on/off tick placement and properly handles a zero value as completely off and 4095 as completely on.
- BYTE
Output
- UINT
Duty
The number of ticks out of 4096 to be active
[[File:]] -
Invert
0=Normal, 1=Inverted
DrawRectangle2D
Draws a basic 2D rectangle onto the LEDs
- BYTE
X1
- BYTE
Y1
- BYTE
X2
- BYTE
Y2
- BYTE
DrawStyle
Sets the draw style - 0=Soild, 1=Edge, 2=Corners
- BYTE
R
- BYTE
G
- BYTE
B
ShiftLEDs2D
Shifts the contents of the display by the number of vertices specified ***Please Note that Wrap mode is currently unavailable***
[[File:]] -
X
Number of pixels to shift the display -1 to 1 / 0 = No Shift
[[File:]] -
Y
- BYTE
DataMode
0=ResetToZero, 1=WrapAroundDisplay, 2=Smear
GetLEDIndex3D
Gets the index of a single LED in RAM as a 3D array.
- UINT
X
LED Column to change the colour / Range: 0 to (LED Column - 1)
- UINT
Y
LED Row to change the colour / Range: 0 to (LED Row - 1)
- UINT
Z
LED Layer to change the colour / Range: 0 to (LED Layer - 1)
- UINT
DrawCuboid3D
Draws a basic 3D cuboid onto the LEDs
- BYTE
X1
Start X pixel coordinate
- BYTE
Y1
Start Y pixel coordinate
- BYTE
Z1
Start Z pixel coordinate
- BYTE
X2
End X pixel coordinate
- BYTE
Y2
End Y pixel coordinate
- BYTE
Z2
End Z pixel coordinate
- BYTE
DrawStyle
- BYTE
R
Red Colour Channel
- BYTE
G
Green Colour Channel
- BYTE
B
White Colour Channel
Inisialises the RGB colour RAM to 0,0,0 = LED Off and clocks out the data to initialise all the LED ICs in the chain.
ShiftLEDs3D
[[File:]] -
X
[[File:]] -
Y
[[File:]] -
Z
- BYTE
DataMode
Sets up the data memory and draws the simulated LED cube on the panel.
Red
Pin that the red LED is connected to.
Green
Pin that the green LED is connected to.
Blue
Pin tha the Blue pin is connected to.
Polarity
Active High: Use for common cathode LEDs - Pin true = LED On. Active Low: Use for common anode LEDs - Pin false = LED On.
Color bit size
Color bit depth. Sets the resolution of the virtual PWM signals driving the LEDs. Lower values mean that the 'Tick' macro can be called less often, but reduced the number of colours that can be created.
Rollover value
The number of unique colours each R/G/B channel can output. Range: 0 to (Rollover Value - 1).
Simulations
